Just got my 1j swapped cressy over the weekend and I'm super happy about it, I reckon the factory "wooshh" sound from the turbo is kinda weird. I wanted to make I flutter and tried blocking off the bov but it still sounds the same, can I get any pointers? It's a bone stock non vvti aside from the dose pipe and pod.
please don't roast me hahahaha
https://www.sau.com.au/forums/topic/475517-how-do-i-make-my-1jz-flutter/
Yikes.
Did you search?
The flutter, from my poor knowledge, is actually not great as its the blades spinning backwards because the pressure hasn't been vented.
If you seriously blocked the stock BOV just to make it flutter then I refuse to answer anymore.
16 hours ago, Dose Pipe Sutututu said:
Blades never spin backwards, if they did you motor would probably stall as there's no where for the exhaust gasses to go
That makes sense.
get rid of the twin setup.
had a t04z setup on my 2jz Mx73 cressida and used to pigeon like a mofo.   Then screamer came on and woke people up.
But those times have passed, due to a wheel axle snapping, back wheel flew off and was never to be found.  Fun times.
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
