Hey folks
I'm wrecking an r32 gtst manual sedan. Approximately 155000kms. The car has had a front end end and the passenger side has some damage (bonnet, fender, reo, rad support bar etc). The rest of the car is fine although the interior is a bit tired. The car wasn't mine previously, I bought it damaged when I had some ambitious plans but I don't have the time so I'm going to part it out.
The car has the usual bolt-on mods - coilovers, FMIC, turbo-back exhaust, bigger turbo, walbro fuel pump, pod etc
Everything is for sale except the wheels at this stage as I might keep them.
Happy to send specific photos and prices.
Happy to ship Aus-wide.
The following parts have been sold:
Steering wheel
Driver side window regulator
Fuel pump cradle
A pillar trims
Shifter boot and surrounding trim
Cheers
https://www.sau.com.au/forums/topic/475975-wrecking-r32-gtst/
59 minutes ago, jmknights93 said:
I literally asked him the same question haha.
And you were in before me.... damn it!!! lol
7 hours ago, R32GOJIRA said:
What is the dash cluster surround like? Are all the switch mounting tabs in good condition?
It has a couple of hairline cracks at the top but otherwise in good condition
4 hours ago, Adz2332 said:
how much on the coils? assuming 2 door and 4 door are the same mounting?
I'm keeping the coils on the motor as I want to sell motor complete with coils, loom, ecu etc
Or are you referring to the coilovers?
Edited by AMR33
30 minutes ago, Adz2332 said:
sorry meant the coilovers
pretty sure coupes and sedans are the same. The difference is between gtst and gtr/gts4, but I'm happy to be corrected on this
asking $800 ONO for the coilovers
how old are they? which BC model are they??
