How long did he have it before you brought it. I don't know mat but I could swere Lachlan had it at one stage
Well, I was told Matt had it for 18 months and prior to that his uncle, no idea on his name, owned the car, but no idea how long his uncle owned it for..
ive been telling people that spend max 250thou on a Nismo GTR and youll be raping the 700000 cars out there. Not sure how true it is but the are almost as quick as a formula one at reaching 100km/hr
And you wouldn't be wrong. The GTR rolling off the factory is only at like 40% max power (my opinion/Guesstimate) - The GTR's were built to be modified - Nissan themselves said this on a Doco I was watching. These cars stock are very close to the Lambo Aventador which sells for $1,000,000 AUD.
Nsimo Williams who has been in works with Nismo to produce the R35 GTR N1 also admitted that there is more room for power. Also the 918 is a 800k car - it may be quick. But I don't think Nissan/Nismo tried to contend with the 918 Porsche. I think that is where the R36 will be heading - "be better then the 918, no acceptations" I think is going to be passed to the R36 creators.
Crazy cars - gives me cold chills thinking about the it.
Holy mother of rajab
That's what is "Said" not proven as per such. I wouldn't doubt it, however it actually hasn't been tested, so who knows ! However, 2.1 is gobsmack and the R36 will achieve 1.9sec. 1second car anyone?
Is the r36 even confirmed?
It is. It is confirmed to be released at the 2016 Tokyo Motor show - to which I am kinda wanting to plan to go and see.
R36 is a hybrid - The torque is electric given it more torque then petrol
Edited by RosieR34
  • 4 weeks later...
  • 3 months later...
Not the best pictures atm but don't have other ones on my phone, will probably come back and post other ones later
I have black manual r34 Gt-t with factory sunroof
Engine:
RB25det neo
3 1/2" exhaust
Turbo timer
BOV
The car made 158kw at the rear wheel on 6psi, am happy with that for now
Suspension:
BC/BR coilovers
Cosmetic:
Full z-tune side skirts
Gtr front bumper and bonnet
19x10 Varrstoen 3.3.2 black wheels
Modification plan has not been set into motion yet, but soon...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
