Please read description very carefully.
Carbon Kevlar and Billet Intake Plenum to suit RB25-DET-NEO motor.
All billet has been anodised satin black.
Plenum has a flange to suit a Drive By Wire (DBW) Bosch 82mm Throttle Body (not included). Brand new genuine throttle can be included for an additional $250 (RRP $350)
Includes a black billet fuel rail (no injectors included).
As far as I am aware the plenum will only fit a NEO. You will need to do your own research if it suits RB20 or RB25. (It will bolt on, but I am unsure about coolant journals matching up).
You will need to fabricate your own coolant lines from Speed Flow or similar. Merge collector for the coolant lines is included. ($250 value). Collector has a 4 x -8 female fittings to a single -20 female fitting on it.
Plenum cost $4000 to have made. It is unused. Blue tape is only to avoid scratching when trial fitting. The merge collector was an additional $250 on top of this.
$3600 with the merge collector $3850 if you need the throttle included as well.
Pick up from WA or will courier Australia wide for $60.
My bad, my apologies it's really been the week from hell. Was a cut and paste job from Scumtree
Edited by masTers
  • Like 1
Just added to the topic. ?
  • Like 1
Pics should be in the first post, I can see them fine. Do they not load for anyone else?
Cheers,
Steve
Pics aren't showing for some in the mobile app at the moment.
They can be seen in the web browser though.
  • Like 1
Am open to reasonable offers on the lot.
I am also open to a part swap of a pair of 33 GTR brembos plus cash my way.
Edited by masTers
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
Sorry back up for sale. Just to be clear, you will need to fabricate your own cooling runners from speedflow lines or whatever you like.
Have a look at the Otkau garage plenums for reference.
  • 6 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
