Hi All,
Newby to Nissans thought I would try something different and later model to what I usually do. I’m an old dude in NSW who loves cars (any type of motorsport car is a good car). I drove a brand new GTR around Amaroo when I was younger and they are awesome cars. I’ve gone 2wd just to get to know the car a bit better and will probably look for a GTR maybe at a later date.  I like building with stock style but with hidden extras and doing some laps every so often.
So I bought this car through the forum and the car is perfect for what I want at the moment. RB20 for the moment, it might stay we will see. I’m not chasing big power but depends when I check the compression and weigh up where to spend some money. Got to find some parts and get rego.
  • Like 2
https://www.sau.com.au/forums/topic/476521-r32-first-build-gtst/
Nice.  That's a charcoal version of mine.
RB20 can make power, but they are nowhere near as pleasant to drive around as a 25. The extra torque, especially off idle, just makes them so much easier to drive around in traffic.  I frequently drive mine 1-3-5 or 2-5, which is not really feasible with the 20.
So I think you either turn the 20 into a 10000 rpm screamer, or plan on a bigger transplant.
Thanks
I’ll look into it for sure, if it makes more sense I will go that way. As for torque i don’t know what that is, my other cars are NA rotarys.
I took the roof spoiler off(not my style)
Edited by Ontrack
Pulled the coils off today to have a look and do a compression test. Compression was all 150 with one just over 140 so that’s fine. The fuel/cylinders smell like lacquer so that might need attention too. One of the coils doesn’t look good either. I will have to look into some new coils, I’m going to change the ECU anyway, might need to to do that a bit early now.
Yes Waiting on some new Splitfire coils and will check the harness too.
My friends keep laughing at me as they tell me it’s a P platers car. I’m suppose to be having a mid life crisis or something. I don’t understand what they are saying, so I open the boot and out comes the sub and amps. Don’t understand big systems in cars. Cars are for driving not listening to music. Don’t get me wrong music is good but engine noise is better.
  • Like 1
Well got a bit of time and the new splitfire coils arrived. I picked up some new spark plugs too. It seems the harness is completely stuffed. I also got the injectors cleaned and flow tested.  Everything I touch falls apart so I have been replacing lots of rubber lines and working out what they do.
Need to clean out the fuel tank next, when I bought it the guy said something about the baffles have been taken out, there is a ding in the bottom of the tank and I guess that has knocked them loose. I will look for another I think and give it a clean inside and out. Put a new pump in. I have changed the fuel lines and fuel filter up front already.
Pulled the pump out today and that might be another problem. The hose is spong and melted. The tank will come out for a proper clean out and inspection. Coil harness arrived too so it might be able to be cranked over on the weekend.
Everything cleaned out, fresh fuel, new coils, new pump and lines.
Primed up, gave it a crank and it started first go. Idled perfect and took it for a little drive, ran good. Need to bleed the brakes next. Then look to see about a blue slip
  • Like 1
  • 1 month later...
Well been busy doing other cars but finally got rego this week. Didn’t need to much, got knocked back on wiper blades, headlights and rear upper arms.
Funny thing was I went to pick up my son from school and a police car saw me from a distance. He had to put his lights on to get through the traffic to catch up to me. Sitting at some traffic lights he ducked in behind me, so I turned at the lights and gave it a squirt up to 60km. He follow quickly so I changed lanes, he pulled along side of me and looked at me. The disappointment on he face was priceless. I think he was hoping to find some young P plater without P’s on but got some old grey haired guy.
The car drives really well, just some cosmetics to fix and it’s a nice cruiser that steps out sideways quite easy.
  • Like 2
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
