5 minutes ago, BK said:
I don't know what cat he's running but the current 80mm Apexi super cats are 130cpi which is awesome.
They are also $1200 - $1400....
ouch.
Probably as awesome as their cat backs with 2.5" reducers inside.
Back on topic, I reckon with the de-cat his problems will go away, if not I think there's a "boost" rag somewhere in his pipe work. We've all been there before :D
5 hours ago, Chrisko33 said:
Ok so the car has been chucked on the Dyno and it pulled 282kw with the de cat still a bit of where it should be
If they won't dyno it with the exhaust dropped do it yourself at home.
Yep, maybe the catback section to the muffler is more restrictive than the cat itself. Needs to be dynoed with front pipe only as I originally suggested and done myself to get a clear baseline of what's what. Are they saying they won't dyno it like that ?
  • Like 1
Currently making them do that right now
Ok so I took the cat straight off back on the dyno made 292kw boost spiked half a pound so there wasn’t much loss between previous run of 282kw with de cat and exhaust. I was expecting to see boost come on quicker still took until 4100-4200rpm. I’m being told valve springs are the issue and change the cooler
There's no evidence of valve springs on the charts, so unless they have good reason to say they think there's float, do the cooler first.
And by "do the cooler", I don't mean replace it. I mean tap into the pipe up and downstream of it and check the actual pressure drop across it.
A 10 kw improvement suggests there is an exhaust restriction so check the rear muffler at least. Stock cooler should be capable of more so as above check pressure either side. And consider trying another tuner.
I’m changing to a 3.5inch x force exhaust now and also doing a cooler pressure check, dare say I’ll be changing the cooler I gained 25kw just in exhaust restrictions so far. What’s to say my cooler isn’t stuffed at this point.Not gonna throw money at springs and cams just yet I’ll do a power run and report back also on the last run it had some slight mis fire on the 292kw run coil pack harness seems to be the suspect as I have brand new coil packs
That slight misfire could also be CAS related, see if they've got the CAS filter enabled, I find Level 1 ~ 2 works well, but a brand new CAS or a trigger kit (crank, better cam, not as good as crank but better than the CAS) will fix heaps of problems.
Just checking - what coil packs did you get?
How is your fuel pump wired?  And how is the A/F ratio and injector duty cycle?
I am asking because I had an episode with my pump not getting enough voltage.  The A/F ratio was fine but injector duty cycle was maxed out prematurely, and I lost about a good 40kw.
3 hours ago, Stixbnr32 said:
Yeh but surely the tuner would figure that out pretty quickly.
The tuner figured out OP needs a cooler and valve springs.  I think it's pretty obvious those two items are getting the no confidence vote here.
  • Like 2
Fuel pump is getting getting 12v that was checked when on the Dyno. Not sure what the duty cycle on injectors are I’ll find out.
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
