Hi all,
Thought i would start a build thread with my car.
Long story short, bought my car off a friend of mine after finding in Japan 3 years ago. It was built as a track car by JUN. After getting registered it had run a bearing after having all the oil trapped in the head.
Car came with the following:
Hks 256 cams
720cc injectors
Z32 AFMs
Tomei manifold
Hks2530
ATS carbon twin plate
R33 GTR gearbox
Cusco 1 way front and Cusco 2 way rear lsd
Ohlins race suspension with adjustable rebound
6pot endless 360mm front brakes
4pot ap racing 340mm rear brakes
Kakimoto exhaust.
Edited by Dorifudo
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/
We stripped the motor down and confirm it had ran #2 bearing, and with bore already at 87mm with n1 pistons it was a no go. Part of the deal with the car was it came with a donor motor however #5 and #6 exhaust ports were oily so valve guides were on the way out.
So with the motor out, i decided that it the best time to freshen the motor up, so dropped the motor down the the rebuilders had the following done:
Supertec racing spline drive
Tomei type b valve springs
Kelford 264/272 cams
Cylinder head ported to match gaskets
CP pistons
Spool Rods
N1 Oil pump with inhouse porting
With the motor back together we got the following accessories:
Ross Performance harmonic balancer with trigger
R35 GTR coil kit conversion
1000cc Bosch injectors
24 and 1 disc for CAS
Being an ex japan car it had a chipped ecu, not wanting to risk it, i decided to go with a Link G4+ with all oil pressure, oil temp, fuel pressure and can lambda.
We got the car tuned and on first tune after run in we made 425whp on 12psi. We ended up with the final figure of 565whp on 20psi.
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7921055
After driving the car for 3 months the front turbo decided it had enough and blew, so now i had 2 choices, replace the turbo with a 2nd one or go single. Not wanting to risk blowing another 2nd hand turbo as they are getting on in age the decision was to go single. After a few nights of researching decided that precision 6466 was the way to go, next was manifold which was hard as they are all about the same price, so after talking to a few guys in the area and decided to keep the money locally and got a local fabricator to build up a manifold.
I told the fabricator, i want something different from the streamlined manifold and after spending a few hours on the net. We decided billet and titanium would be very different. So we went with a billet T4 merge collector with 1.5" runners with twin wastegates, titanium downpipes and titanium screamers.
With the fuelling now a possible issue, i upgraded to a surge tank in the boot as i had experienced fuel surge when i was under 1/2 tank, so gone with a surge tank with built in twin 460lph pumps and using my 460l intake as a lift pump.
  • Like 1
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7921056
18 hours ago, Shoota_77 said:
Nice! Vinny Fab do some great stuff. Manifold look awesome.
Look forward to seeing it all come together!
Yea super stoked with the quality of work as well, cant wait to see how it goes with long runners and 1.5" tubing
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7921104
Another update this week, titanuim arrive so the fabricators got it all welding up today. Plumbed up all the piping and everything is bleed and ready for tune.
Edited by Dorifudo
  • Like 1
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7921501
  • 1 month later...
Finally got the car tuned today, well kinda of full tune on 100 octane made 502rwkw on 24psi and 616rwkw on 31psi with E60. More to go tomorrow as we will bump it up to E85 and maybe a few more psi
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7923823
  • 9 months later...
Well its been a while. Had the car back on the dyno due to a fuel pressure cut and decided while it was on the dyno diagnosing problems we would tweak the tune a wee bit more. Ended up only making an extra 10hp however we had gained 50nm throughout the whole rev range. So now making 626rwkw and 950nm.
Had a drag event on last month so decided to take the car down and give it a shot on the stock box. To anyone who thinks drag racing is easy...well its not my first pass was a 12.5@126mph as the car completely bogged and almost stalled 😅played around with the launch control and managed a slightly better 11.5@128mph. Then for the last pass as i needed to go to a birthday party i just sent it and ended up with a 10.3@143mph. **please note the 60ft is 1.802 not 0.802 haha
  • Like 2
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7943819
31 minutes ago, Dorifudo said:
Hey @BKi opted for the synchro box as I still wanted a semi comfortable street car haha
I'm crushed !
4 hours ago, BK said:
You would  have absolutely got your 9 with the PAR box coming, if it was the dog box
Sorry, fixed my own post. Man, I was all pumped for you to start banging gears through with the 6466 !😁 Sorry but it will be pretty hard to bang a 9 out with a synchro box. Not impossible - but very,very difficult. I like the 143mph trap though 👍 and if I'm somewhere similar with my 6466 setup after the final tune I'll be pretty satisfied.
So I take it you've got the straight cut PAR synchro set coming then ? I am still very keen to hear feedback from this transmission once in as this would be my choice for a synchro gearset over an OS giken these days.
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7943868
21 minutes ago, BK said:
I'm crushed !
Surprisingly tho, my current stock box has no issues flat shifting at 9k rpm. I messaged Neat last week and the input shaft was getting heat treated, so once thats all done it shouldnt take too long. Fingers cross it will arrive here after new years, also opted for the OS centre billet plate as well.
Edited by Dorifudo
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7943871
It will eventually if you keep doing it. Remember even on your new PAR synchro box, they are just standard Nissan brass synchros. They only tolerate that sort of abuse for so long, then you'll see this on your transmission drain plug:
  • Like 1
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7943873
Yea, the stock box really is a ticking time bomb.
I did consider the PAR dogbox, but unfortunately not many people near where i live has a dogbox to kind of get an idea on what its like for a daily.
At least i got a good deal with Sam, i could sell it and go dogbox later down the track.
Another hard thing to justify going all out is we only have 6 drag meets a year, and after my last stint i am banned until i get a full cage.
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7943876
I love H pattern straight cut dog boxes. Would I put one in a daily or even fairly regularly driven car ? - HELL NO !
I've got an OS giken gearset in my 33. I love that box in that car and would never put dog engagement into it so I completely understand where you're coming from - good choice.
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7943877
  • 1 month later...
Just had an update from Sam at Neat Gearboxes. Gearbox build is in its final assembly and will be shipped in the next few days. Pretty excited to say the least. Opted for the PAR straight cut synchro 1st-4th with stock 5th, PPG centre billet plate and upgraded 26 spline input shaft.
  • Like 4
https://www.sau.com.au/forums/topic/479343-jeff-r32-build/#findComment-7945786
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
