Hello and once again i cant get things right?...
i have a freddy greddy intake and shown below is my vacuum diagram. I plumbed the vac line from precision turbo 38mm  wastegate directly from the intake manifold with no “T‘s” or any sharp bends or obstructions with 2 zip ties on each end. Its about 3 feet long and its plumbed exactly to the instructions diagram A. shown in the picture i did it this way As i do not have any electronic or manual boost control as its started life as a de/na rb25.
i went for a drive and made 18 psi and the gate did not open... i put a “red” 6 psi spring...
what the heck is going on?
First things first, do NOT hook up the boost source line from the plenum. You really really want that signal line to come from immediately after the turbo, not downstream of the throttle. The pictures tell you the best place to get it.
Second things second.....does the wastegate even move? Is it stuck? If you put compressed air on it instead, will it open? Etc.
Damn bro, thanks for the info.... i guess i have to tap the intercooler piping right after the turbo because the compressor housing did not come with a nipple/barb. But u dont think that if the boost gauge reads 18psi from the manifold, the wastegate wwouldnt read the same and then open? I believe testing the wastegate with a compressor is the best bet... thanks
That's not the problem. The problem is that the wastegate is supposed to control the boost made by the turbo. If you connect downstream of the throttle and have the throttle partially open, there are conditions where the boost can be much higher upstream the throttle than it is supposed to be. The turbo ends up working harder (more exhaust backpressure) than it needs to. This is actually not a problem a lot of the time, but some very bizarre boost control problems sometimes happen when it is set up that way. It is far better to simply avoid it by doing it properly.
  • Thanks 1
But... yes*
In the scenario you described, it should open, barring some scenario where the vac line on the wrong side of the gate (if it has two, etc).
This is likely why GTSBoy said test it off the car to make sure it actually can open.
  • Like 1
Might have a split in the diaphragm. Actuators/gates only really want positive pressure. You have picked up actuator feed after throttle, giving it boost and vacuum. Picking up before throttle generally eliminates vacuum.
Feeding an actuator vacuum will try and pull the diaphragm in it the wrong way when throttle is closed, sometimes damaging or jamming them.
Boost gauge, Fuel reg and bov want boost and vacuum (after throttle), Wastegates and boost solenoids use boost only (before throttle). This is the way the factory does it for a reason.
As above need to check that your actuator works with a regulated air compressor to confirm it actually operates at all first.
  • Like 1
Shit... i hope not it is brand spanking new but what u are saying makes sense, i will get back to guys tmm on the progress, i know this sounds like a silly question but what is the best way to add a lil nipple/barb to the aluminium intake piping right after the turbo?
Drill hole. Weld on fitting.
You can thread a fitting into a hole in a thinwall pipe....but i'ts a bit shit,  very highly recommended not to. If you are talking about aluminium casting, you should be able to tap a thread into it, but you need to be very careful about drilling and tapping swarf (ie make sure it doesn't go inside the pipework - preferably do it off the car).
I just drilled and tapped into the compressor housing using grease on the drill and tap and doing a little bit at a time.
thats pretty ghetto, at least the intercooler will catch the big chunks!
if i was to do that, i would use a garden blower or compressor to pressurise the pipe work to shoot it back into my eyes .
friends and family... i am A class bone head.
Upon further inspection, at the back of the wastegate there are TWO!!! Vacuum ports on the bottom on eachside so you can route a line to closet side when Its installed. I did not see it and Left it open and they even provided a blank/cap to close off the port that you are not using.
An important lesson was learned today, do not smoke and then go playing mechanic on your car. It could of easily blown shit up when i made 20 psi
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
