What do you mean "conversion"? Are you talking about using original panels? You do realise that the R32 and the R34 are completely different shapes, right? You won't be able to stitch the rather vertical sided guards of the 34 onto the somewhat more curvy rear half of the R32 guards.
Any such conversion you have seen done before (like the S15 onto S13 strawberry face conversion) involves complete replacement panels in fibreglass. Not steel stitched to steel.
I'm not saying it is impossible, but it is not something you just "do". This would be a massive custom bodybuilding exercise to be undertaken by a skilled panelbeater.
Most likely using the rear half of the r32 fender and blending the r34 front half to it but that’s why I’m asking... If I have to make a custom fiberglass fenders that’s not a issue. Thanks for the input but I’m looking for actual experience on the topic. I get that it could be a little bit more work than a r32 core support replacement and that’s no problem either. I have time.
So, did you search? More than 20 years of actual stuff on this forum alone.
viz.
Most of these use plastic.
https://www.google.com.au/search?q=r32+with+r34+front&tbm=isch&source=univ&sa=X&ved=2ahUKEwjkuNjK6PLmAhUFxzgGHRi9CcYQsAR6BAgGEAE&biw=1779&bih=888
Edited by GTSBoy
viz.
Yes most are a dead end or not the way I’m doing this conversion.
Edited by Chris D
14 minutes ago, niZmO_Man said:
Bee*R did it like a decade ago.
https://www.rhdjapan.com/bee-r-b324r-full-swap-kit-skyline-r32.htm
What's so special about your project? You want to blend the two panels together? Cool. Let us know how you go.
Yes they did but they used the r32 core support.
Which suspension do you propose to use? The upper arm mounts to the inner guard are totally different between 32 and 34. If you're talking about using 34 radiator support panel, then it only makes sense to use the inners as well. And then you're forced to use 34 suspension. Not that that's a bad thing, as it is much better than the 32. But you're talking about major surgery of both the inners and outers.
I don’t plan on messing with any of that. I’m gonna swap on the 32 core support with the 34. I’m sure there will be some fab work to get it on.  I only have the front nose not the whole front clip.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
