Hi Folks
You may be able to search for my rumblings and complaints over the years how my 1.5 way was a bit clunkier around town than your regular 1.5 way and how I wanted to fix that to no avail.
Upon finding a unicorn R34 Helical, this diff is now for sale. As I know people would want to see the center before buying a rando diff, I took the cover off and found that it was actually a fkin 2 way diff the entire time.
It was recently rebuilt from scratch to try and find "the problem" and of course there was none, which was... quite a lot of money not so well spent on my behalf, but hey this diff has been entirely rebuilt for your pleasure.
Will bolt and plug in directly to your R34. I can confirm this thing locks up HARD in both Accel and Decel scenarios.
You could use it on the street, I did for quite a long time it turns out and I did not die. However, I wouldn't recommend it for a daily.
$1200 obo.
Pickup strongly preferred!
  • Like 1
https://www.sau.com.au/forums/topic/479871-r34-gtt-nismo-2-way-diff-whole-diff/
  • 2 months later...
Fit, physically? Yes
ABS though? Your guess is as good as mine. The R34 has 2 ABS sensors one on each stub axle, the R33 has one (or none). Can you just... put the sensor into one of the ports on the stub axles?
Maybe? Yes? No? Maybe the cable won't reach/needs to be extended?
You'd be a guinea pig in that aspect.
Could you pull the center and driveshafts out of my diff, put them into a R33 ABS R200 housing? Uh, maybe? Again not sure. Depends on your confidence and how much you care about ABS as far as I know...
No. Different pulse rates vs speed.
Yes, of course. Although you will almost certainly end up paying for diff setup here, as the pinion from Greg's diff will have to be put onto the R33 diff's input /pinion shaft, because I think that the diffs with front ABS have a longer housing*.
(I might be wrong, but it looks like it in various piccies I've seen.)
I was really hoping GTSBoy would find this thread, because all I can confirm 100% (with no taking anything apart, bolt/unbolting centres) is that it'll go into a 34.....TURBO ?
  • 1 month later...
Cmon folks, surely someone wants to do a skid.
Technically this is a 1.5 way, it's just everyone thinks 1-ways are actually 1.5 ways.
  • 4 months later...
It would appear noone wants to do a skid. This is now a 1.5 way. It's always been a 1.5 way, because anything between a full 45 degree 2 way, and a 90 degree 1 way, is a "1.5" way though it could easily be referred to as a 1.2 way or 1.75way or 1.9way.
If you have a 34 get a diff. Specifically this one.
It is 4.111 (or 4.083 if it originally came for an auto) which has.. 0.5kmh difference between the two in any one gear.
  • 6 months later...
Sorry no - It's been sold, I didn't close the thread off due to bumping it from oblivion seemed un-necessary.
It has gone to a new home, namely a madman who is putting a E60 V10 into a R33.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
