so probably been beaten to death, I apologize.
so in a nutshell for a 30 swap in a r34 GTR. I would need to:
get the awd adaptor
drill a hole for an extra tensioner
and make the crank collar longer?
will the getrag bolt on directly to the motor?
am I missing anything else? Are there instructions on where to drill the hole for the tensioner?
https://www.sau.com.au/forums/topic/479957-2630-build-questions/
Yes, Yes, no necessarily (longer oil pump drive is desirable not required), not exactly (the lower bolt holes will be off between the sump and gearbox by the height of the awd adapter. depending on how much that troubles you I've seen some people just leave the lower bolts out, my gearbox was redrilled for the new lower bolt locations.
The rb30 pdf guide has information on tensioner options, and depending on the block you get you may already have to location for the tensioner machined, or you may need to get that done. There can also be differences on whether the required oil feed and returns are in the block or whether you have to drill and tap them
beyond that, motor prep is like any other rebuild (you can decide how far to go), and things like radiator hoses will not fit directly and will need modification.
And finally, I think it is a terrible idea to put an rb30 in a R34 GTR these days. Start with something people don't care about like a 33 GTR instead (no one cares about middle children).
I had a built rb26 with a t88. Unfortunately dumb shit started to happen and I got the car stolen and it came back with a blown motor and turbo. But I stumbled on a rb30
thank you for the information Do you have a link to the PDF on hand? Or a thread with your build?
2 hours ago, KiwiRS4T said:
Or you could just buy one...(from short block to complete engine)
https://www.ripsracing.com/catalog/Complete-Motors-40/Complete-Engine-Package-32.html
Totally an option if it wasn’t an arm and a leg to ship the motor from there to here. I was looking at a spool short block at one point
  • 11 months later...
1 hour ago, mugiwara no luffy said:
will there be clearance issues with the bonnet and the block.
Some have had issues, I did not (R33).  Mate, custom engine fitting requires an optimistic ' suck it and see approach" my 25/30 went straight in, I could have dicked around for hours making mounts beforehand that would not have been required.
Ah nice. I heard there was no clearance issues but I wanted to make sure.
now to compensate for the extra height I need to modify the down pipe, intercooler piping, and radiator hoses correct?
SOME have had clearance issues, block height is about 20mm higher, my point was you will not know until you check after fitting.
Thanks for the info
I just bought some spacers from prp just in case
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
