You are correct r32 Gtr manual states front right sensor....try cleaning it, it’s very easy to take off. Just curious are your abs and 4wd light on? I just went through all this shit I’m sure we can solve it quick.
Edited by MoMnDadGTR
ok so you currently are in 2wd.  so lets get this beat. 1. make sure you have a good positive and negative connection to your battery. 2. check the main ground from battery to frame to engine mount. now that the grounds are good make sure the connection for the wheel sensor is actually plugged in. its near the drivers side strut tower in the engine bay ill take a picture for you. as far as cleaning it goes, im sure you could even just wipe it if you remove it, I used brake cleaner.
No I’m pretty old school mate no Facebook, could be a good thread for others if we fix it as well. I know when I was fixing my error codes I found lots of threads with unsolved mystery ha. Here’s a picture of abs connector for right sensor.
Okay i can confirm my one is connected. But maybe it's not a solid connection whete there may be crap contact.
I'll pull out my sensor and give it a clean after work today.
My battery was relocated to the  boot after my engine build. My awd was working perfectly before
I'll relocate the battery ground cable as it is now connected to the boot latch nut there. I might try the strut tower?
I also chased wires like you until I replaced my atessa computer in the trunk of car(atessa control unit). mine had water damage from my rear windshield sprayer leaking and was telling me codes that weren't real. check for power and continuity at that clip as well that I just posted if all else fails. hoping that connector is loose as your issue.
if it was working before I wouldn't think move the ground. be patient. my car is setup very simple(no battery relocation or anything) so it was very easy to diagnose and fix. there are some super rebutable guys on here im sure they will step in if cleaning it doesn't work. just a question what ecu are you running? ive heard and seen guys having awd problems with apexi jetro systems...if you still have a stock ecu try a different one if you can get your hands on one
https://www.gtrusablog.com/2017/05/r32-nissan-skyline-gt-r-attesa-code-1.html
this is a link for trouble shooting your error code, im 99 percent sure this will lead you to your issue...the manual has worked every time for me in solving these attesa codes. I would print it off(about 800 pages so use your works printer full r32 gtr manual) if I was you is a gtr bible!
I highly suggest trouble shooting it with the link I sent you. (It’s straight from r32 gtr manual brotha) This will rule out things quick if you know how to use a multi meter. Way better than guessing but hope it works out.....all you have to do is pull the plugs from the atessa control unit and get to work.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
