You are correct r32 Gtr manual states front right sensor....try cleaning it, it’s very easy to take off. Just curious are your abs and 4wd light on? I just went through all this shit I’m sure we can solve it quick.
Edited by MoMnDadGTR
ok so you currently are in 2wd.  so lets get this beat. 1. make sure you have a good positive and negative connection to your battery. 2. check the main ground from battery to frame to engine mount. now that the grounds are good make sure the connection for the wheel sensor is actually plugged in. its near the drivers side strut tower in the engine bay ill take a picture for you. as far as cleaning it goes, im sure you could even just wipe it if you remove it, I used brake cleaner.
No I’m pretty old school mate no Facebook, could be a good thread for others if we fix it as well. I know when I was fixing my error codes I found lots of threads with unsolved mystery ha. Here’s a picture of abs connector for right sensor.
Okay i can confirm my one is connected. But maybe it's not a solid connection whete there may be crap contact.
I'll pull out my sensor and give it a clean after work today.
My battery was relocated to the  boot after my engine build. My awd was working perfectly before
I'll relocate the battery ground cable as it is now connected to the boot latch nut there. I might try the strut tower?
I also chased wires like you until I replaced my atessa computer in the trunk of car(atessa control unit). mine had water damage from my rear windshield sprayer leaking and was telling me codes that weren't real. check for power and continuity at that clip as well that I just posted if all else fails. hoping that connector is loose as your issue.
if it was working before I wouldn't think move the ground. be patient. my car is setup very simple(no battery relocation or anything) so it was very easy to diagnose and fix. there are some super rebutable guys on here im sure they will step in if cleaning it doesn't work. just a question what ecu are you running? ive heard and seen guys having awd problems with apexi jetro systems...if you still have a stock ecu try a different one if you can get your hands on one
https://www.gtrusablog.com/2017/05/r32-nissan-skyline-gt-r-attesa-code-1.html
this is a link for trouble shooting your error code, im 99 percent sure this will lead you to your issue...the manual has worked every time for me in solving these attesa codes. I would print it off(about 800 pages so use your works printer full r32 gtr manual) if I was you is a gtr bible!
I highly suggest trouble shooting it with the link I sent you. (It’s straight from r32 gtr manual brotha) This will rule out things quick if you know how to use a multi meter. Way better than guessing but hope it works out.....all you have to do is pull the plugs from the atessa control unit and get to work.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
