Got my quote for a cam and stuff install.
Waiting for workshop time now.
oztrack-camshaft-kits-with-remote-custom-tuning-afm-delete-removal-cam-upgrade-online-leaders-in-ls-auto-part-tire_709_250x250@2x.jpg.4657e7a70c1e18cef044f9f6ef46454a.jpg
Cannot decide on which one though.
Oztrack recommend the LSV or HP3.
They recommend that LSV would suit the car as is, but the HP3 has headroom for intake manifold and head work in the future.
LSV idles smooth and comes on fairly quick.
The HP3 is fairly choppy (I love the sound of a lumpy cam) but still ok for the stock converter.
Both are a big improvement over the current cam, lots of gains in torque and between 30-50kw up high.
I'm leaning towards the HP3 maily because of #lumpyloapylols, the 3.9 diff gears should "hopefully" help it get up into the cam without to much delay.
Streetability for both are apparently good.
Hmmmm
In other news: my fears of a highstall and not locking up in the auto are unfounded, soooo, if I do go the bigger cam, a high stall converter will be the next mod.
Now all I need is that WSID opens soon so I can do a pre and post run.
LOL, f**king Covid spoiling all my fun.
Hmmmm
LSV out of those choices. THe LS1 doesnt need / beneift from such a large exhaust duration split.
choppy idle can be tuned to suit.
glad you have seen the light regarding conveters!
  • Thanks 1
You are going to run into the exact same problem I did re: Cams and the rest of the system being able to supply the air the cam wants.
Be aware!
If you are going to keep stock heads (and not be super obsessive about checking springs, etc etc, want something that will be put in and forget) then the LSV is the smart choice.
The "power" category of that chart does require additional mods to unlock the said power. Drivability is easier in an auto which you have on your side. Cam surge is just shit to live with. Power under the curve is still a thing in V8 land.
  • Thanks 1
Be aware!
I've been looking at heads and an intake, the intake is relatively cheapish, the heads are costly, sooooo
Thanks all for the information, I'll have them throw in the LSV with the all the other snot they install at the same time.
It is diminishing gains (especially value for money wise) when going further than just a cam / spring job.  As kinkstaah said area under the curve is still important, and going to a larger can will hurt economy also
  • Thanks 1
Car goes in tomorrow.
The guy recommend trunion bushing kit?
They look like solid brass vs roller.
Like this > https://vcmstore.com.au/products/ls-rocker-trunnion-upgrade-kit
Thoughts
Thoughts
Wrong part number and link for nitrous kit
  • Haha 1
Thoughts
I vote no. I would be more concerned the trunnion galling when solid, considering the way they are lubricated is "hoping the oil splashing around happens to land there", push rod style! .
  • Thanks 1
Its less choppy than mine. That said it probably drives right, and doesn't shake you and your passengers at idle in the seat (is kinda cool tho) and is the right cam! Which one did you go in the end?
LSV
It does do a "little" shimmy at idle in neutral, once in drive it just squats down a bit harder on the brake.
Thats really what you want man.. Idle shake is cool and all until you have anyone in the car that doesn't think its great and it quickly becomes shitty.
That cam looks the goods. Was the dyno run locked?
So, after taking the Mrs for a cruise today (Robertson pie shop, long way there, long way home) I'm definitely looking at those interceptor copies in silver, with caps of course, #fullbogan
17 x 8 + 42 for the front
17 x 9 + 48 for the rear
Tyres will be Hankook RS4, cheap but good.
235/45 front and 255/40 rear
Rollin' on 19" rims and rubber band tyres is arse on anything other than dead flat and smooth highways.
I'm just waiting on a shipping quote.
In other, Mrs related news, she wants me to put the pacemaker rear muffler back on, doing a dollar ten on the highway with 3.9 gears is to noisy for her to sleep.....LOL.
Meh, things you do..
I'm also still looking for 2 interceptors, 15 x 7 which I will shod with some Micky T's for LOL's at WSID.
I believe the converter was locked.
But, my speedo reading is way out now, I believe they f**ked up the calibration it had for the 3.9 diff when they played with rhe tune.
GPS reads 80, speedo reads 100.
How and if this effects anything I have no clue, apart from me driving like Miss Daisy.
I'll ring them tomorrow to get it fixed.
I was doing what I thought was 100 in a 100 zone and everyone was passing me, I got the Mrs to get google maps up and to my dismay I was doing 80.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
