Finally installed the Forsa FP2 brake pads in the front
Flushed the fluid and bedded them in
Old pads were QFM HPX
So far so good, good cold bite, good feel, seem to be a good street pad
The HPX pads in the rear still have a bit of life left, I will try the Forsa FP1 in the rear when the HPX and done
  • Like 1
Had a major service done on my lateral compartments
+20kw plus improved throttle and brake control
As you can see I am bedding them in now
Also went with some tint, all the cool kids are going orange
  • Like 1
Fitted the Forza FP2 pads in the rear to match the fronts I put in last week
Also purchased a little mechanic seat thingie with wheels for working on the brakes and suspension, makes life so much easier
  • Like 1
what happened ulleh?
Years of running and carrying a pack ended up screwing up my lower leg muscles, in the end when I was walking long distance the compartment stuff (sausage skin) that covers the muscles didn't stretch enough and the pressure started to cut off blood flow to my feet.
Should be all good now.
In other, more boost orientated news: the car is booked in on Monday for the charger, again, it cannot come quick enough, I've had to change the dates for getting the charger installed twice already, once for work and once for the surgery.
This time next week should be fun.
  • Like 1
So, the dyno results hey
With the blower at around 5-7 psi at it, it got to 317kwatw and about 950nm...
So a gain of about 47kwatw, but a extra 500nm of gearbox destroying, rubber laying torque
From talking to the tuner though the final kw number and shape of the curves can be taken with a grain of salt because of the highstall slipping, and stuff....... yadda yadda yadda......meh........it's all black magic to me
On the road, it's a freight train, I could only give it a little hit, but the before and after difference is, well, big
My next thing to do is revisit Craig's Automatics to adjust the autos tune, so it locks up a bit sooner, "or something" then hit the strip to see what it really does in anger
Overall, on day 1, I'm happy and haven't broken anything, yet, well, apart from traction
  • Like 8
I needed to pop back in to get the speedo calibrated, it was set to whatever the stock centre was.
I called and talked to Spiro and he said pop in whenever I was available, I said I am, he said bring it on in, so I did, he also stuck it straight back on the dyno and tickled the tune a bit because he wasn't happy with the idle when off throttle.
Excellent service
Everything is GTG now, plus I just took the long way back to work
It is nice and whiney, on the throttle, but not overly, you can only just here it in the cabin, which is nice, outside, it sounds :)
The car cruises like a dream
Coolant temps, on the stock gauge at least, hasn't changed, even when I was sitting in traffic for 10 minutes trying to get off Parramatta road
As for bonnet clearance, it easily fitted and there was no need to chop up my new under bonnet liner thingie, winning....
I might paint the trans cooler black to hide it a bit
  • Like 5
After a quick squirt with brake clean and some flat black rattle can action, I present......stealth mode
It's still wet but you get the gist
With no actual hands on prep, the fisheyes on the hoee clamps, and a few missed spots behind a bracket or hose, it is just like a Holden quality paint job...poor quality
IMO it does look better than before though
  • Like 4
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
