MLR's Bogan cruise ship
In other news, I'm looking at some new cats, the current 100 cell cats are of questionable quality and don't really do much, the Mrs has made note if the "stink" from the exhaust
I love the stink, but, as long as I keep her relatively happy with the noises and smells the car makes I'm pretty much free to "mod away"
Plus if I was ever pulled over and sent to a emissions test I'm not confident it would end well
So.....
I'm looking at some 400 cel euro 5 type (the 2002 vx is euro 3) from Racecraft which are currently at $450
This is about half the cost of a quote from an exhaust shop that quoted me for 200 cell, which really wouldn't be much better than my current 100 cell
I was able to buy some 5in body 400 cell cats (x2) which had 3in pipe either side. I can confirm they work and may be cheaper, I want to say they were just under $200 each.
Venom Exhaust Weld in high Flow stainless 3" 76mm 400 cell Cat Catalytic Converter (mrcperformance.com.au)
They do remove smell, because I have 'cat delete pipes' that can be swapped in with vbands.
These delete pipes sit in a box, because.. they do not seem to impact performance at all, and fix the smell, and .. well, the cats make the car sound better lol.
Won't pass an emissions test though. Used to have one on my car when it was a street car, but it failed the Euro 3 standards even on E85. Was going to buy a certified Euro 4 cat to replace it but ended up taking the car off the road instead.
  • Like 1
Mine did... for the same year/motor combination that OP has 😛 through the IM240 in NSW which is far and beyond more stringent than the 5 gas test WA does.
The kicker for me was it was the only one I could find that was a 3in 400 cell cat, and its worth mentioning I have two of them, one in each bank, as I have a 2x 3in exhaust into a 3.5in.
... and they are also behind 100 cell cats, which are further up the bank!
Just sayin they do work for the make/model that this thread is relevant for, but I probably would have paid the extra for the racecraft ones, but trying to get information on them other than "Cell" and "Euro" spec was impossible at the time.
Fair enough, I stand corrected!
I'll admit, I had never noticed any smells and when on 98 it would take a good few months of driving without washing before any soot developed on the rear bar, so they obviously did something. I had always been content with it until it failed the emissions test, which as you say is only a 5 gas test. My package just needed a different combination I guess.
It is interesting how the tests are run, my car was well worse on idle instead of driving around, given the WA test is an idle test mileage may vary. My stupid V8 cam was a huge detriment though. (unburned fuel is bad for emissions...)
I would have gone ceramic if I had've seen them prior though, because its probably better than steel ones, otherwise why would every OEM use ceramics instead of steel ones. But now that I'm passed I'm happy they're steel, so who knows, worked out in the end.
Either one will remove the smell though!
  • Like 1
How did you find the 400 cell in relation to the tune, did it richen it up by much?
This is how I figure it made no difference, closing the varex for example richens up the AFR significantly (12.9 to 11.0) as revs climb for obvious reasons, and about half a point at idle actually. (14.7 to like 14.3ish).
Swapping the cats (plural, I have two) with 2x 3in straight pipes resulted in an 0.0 AFR change at the same road with same conditions, I made a day of it specifically testing this exact thing. And the cats fit better. I wish I had flex joins in my exhaust, vbands are great but... there is 0 compliance with them.
  • Thanks 1
After a nice ride on the Harley this weekend, I removed the lowered rear shocks
I went from scrapping pegs to scrapping the exhaust, which is not ideal when laying this fat old girl over in a tight corner, the exhaust turns into a solid pivot point
I actually felt the rear tyre lift and lose grip
The OEM rear shocks are back on, not the best performer, but at least I'm back to scrapping pegs and not pivot points
In other news, after no email reply from Racecraft, and as they don't have any phone numbers because phones are apparently to hard to answer (well that is what their website says), I got a local exhaust shop to fit the cats.
The fuel/exhaust smell is now gone, which is nice
The ended up costing $650 installed, I'm happy with that as it saved the whole "I hope they fit" senario you go thru when ordering "bolt on" parts
It also gave me the opportunity to inspect the undercarriage and "stuff" when it was up on the hoist, doing that on jack stands is a PITA, after inspecting and shaking the bejubus out of all the arms, linkages and other bits and peices everything was hunky dory, sweet.
  • Like 1
Just purchased a bonnet scoop #becausemadbogan
I just need to find a clean bonnet to hack up
I'll fit it up and get a local joint, Fineline, to respray/color match the bonnet
  • Haha 1
Water squirter relocation stuff is ebay'd
I need to hit bunnings tomorrow for some cutting wheels for my little grinder, I will be just removing the bonnet material and leaving the frame untouched
Then tape tape and chop chop
I actually also did some wool tuft testing, well, I used survey marking tape, anyways, it seems the "advertised" high pressure zone at the base windscreen isn't really a high pressure zone, the tape pretty much flowed up the windscreen, it wasn't smooth, but it didn't push down into the lower part of the screen, which to me would indicate that it should, "in theory" vent heat when moving
My initial hopes were to remove some heat when the car is sitting stuck in traffic, it actually "may" vent some heat when moving, maybe...meh
This isn't because the car is overheating or any real reason other than another "just because" mod, plus I get to use my grinder
s-l140.jpg.b1fbd6b55b7178f6aa9142a090b3af56.jpgs-l140-1.jpg.2ab5a8e41a8b76f329daf7940b63325c.jpg
13 hours ago, Dose Pipe Sutututu said:
How's that burn out video coming along? Lol
Give me a break, the car has sticky street tyres, 255 RS4's, and only 950nm of torque at 2500rpm
I'm not sure if that's enough powahs to turn them
  • Haha 1
Sounds like it's just enough to pull a Mah de Grass float.
  • Haha 2
Unfortunately I will not be able to tow your float as I have removed the tow bar
I appreciate the offer but sadly I don't tow that way, not that there is anything wrong with it, it is 2021
Anyways........
In other news, me the Mrs are taking the bogan mobile into the city to pick up the eldest after a work function
The plan is to head from Holsworthy to the city, via Chronulla, then home from the city via Manly for Icecream Waffles
Pity about the weather but meh
Good times anyway
What information do you need that you don't currently have?
ODBII can be done via a phone app in a far easier way, provided the LS ECU actually has transmission temperature sensors/readings that are transmissable that way. (I know IAT is)
I also know your IAT reading will be inaccurate.
I also know it will be messing with your tune/AFR as a result of it.
Its cool like that, assuming you have the stock sensor now that you have boost
  • Like 2
It's just a consumer thing
I shyed away from the Bluetooth OBD2 as I've heard a few issues with accuracy and also playing silly buggers with slush box converters locking up, meh, electrical black magic stuff
Plus I use my phone with MAPS alot
So, plug in
Why, I'm curious as to what  my:
Trans temp, the 4l60e has a temp sensor in it, it has a cooler on it but I will be more confident when I know the actual data
IAT, it has some aftermarket thingie that reads charge air temps post the water to air intercooler, I'm curious how it reacts to things like traffic, cruising, or rolling against Ferrari's.........JK........but seriously
I'm planning to run AIT, Trans temp, volts and another thing that takes my fancy on a day to day basis for shits and giggles
In the end it's only a little thing that doesn't take up much space, I'm thinking above the rear view, the VX headlining and A pillar lends itself well to running a small cable from the roof line to under the dash
I totally agree, I think an OBD display is a good thing to keep an eye on "stuff". I run an informeter in the fuga, to the left of the factory screen
I run one in the Titan too, and in that case I added a trans temp sensor in the line to the oil cooler to understand how that is going when towing on hot days in addition to the built in data.
In the stagea I run a gaugeART to the Link, it fun to watch the whoosh appear.
 Share
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
