On 13/05/2022 at 8:22 PM, Dose Pipe Sutututu said:
Wot, damn...
Money they couldn't resist I suppose.
One possible benefit is due to opening up to the huge US market prices might settle a bit
Currently the 2500T goes for around $4500, then add in pinning it in, and tuning, and the other "supporting" stuff that it needs,  it will be a costly endeavour
You seem to be all over "tuning and stuff", do you have any experience with torque management????
Fom my research the Haltech  torque management is awesome, and there's no point in having alot of powers if you cannot lay it down
In theory I know how to set it up, and know how to adapt different strategies to manage torque such as reduce timing on wheel slip (and ramp the time retard as wheel slip % increases), and/or apply the same on the DBW throttle body as wheel slip increases you decrease the max amount the throttle can open. For boost applications you can even trim duty cycle etc. Then all of that you can even throw on-top random cylinder cuts to reduce large amounts of torque.
I'm planning to install either a front wheel speed sensor OR (lazy way out) a GPS sensor and calculate slip % then apply whatever strategy above works most effectively and efficiently. Just avoiding the full cut traction strategy of boring A to B OEMs.
www.racetcs.com
By far the simplest way for what you want (which is wheelspin due to power)
  • Like 1
On 14/05/2022 at 8:08 AM, r32-25t said:
Haltech themselves also say it’s not true
Cool, my info must be off, the guy I was talking to was pretty confident and says he is tight with the owner
On 13/05/2022 at 11:01 PM, Kinkstaah said:
www.racetcs.com
Looks like the old race logics one
Pretty cheap, which sort of worries me
I wonder who can wire this puppy up for me?
  • Like 1
It is basically the racelogic one that I have, and works really well with minimal f**king around, it doesnt take a lot to get it to function better than you expect.
Anyone can wire it in. As long as you can identify your injector wires, and your ABS/wheel speed wires from the factory car, you can splice this in. It'll work with the factory ECU as well, and by work with I mean entirely independent of, which doesn't cause a problem with the factory ECU, basically.
  • Like 1
On 13/05/2022 at 11:26 PM, r32-25t said:
I can’t find any information about Holley buying haltech
I just heard about it over on performance forums. The guy who brought it up is a haltech distributor. He said it's been sold to US company race winning brands.
Regarding halaltech
Holley did make an offer to buy but haltechs owner knew it would have been the end of haltech and didn't accept their offer. So there was truth in what you heard @mlr
https://www.businesswire.com/news/home/20220511006064/en/MiddleGround-Capital-Completes-Third-Add-on-Acquisition-of-Haltech-for-Its-Race-Winning-Brands-Platform
I never did a video on how well mine worked/didn't work as there's enough out there from the various manufacturers.
I can let loose in 1st at 5000+rpm in the wet and the the car just drives straight. It does wiggle a bit relative to how much slip I dial in on the dial.
You would know that letting off otherwise at about 2000rpm results in a hilarious burnout on road tyres, even if you never posted a video of said rubber destructive test.
Caveat to above audacious claim: Mine is configured to kick in at 4kmh, (the nissan sensors don't pick up a reliable speed lower than that on all 4 wheels) so I have to get the car to 4kmh before truly just going flat foot on the accelerator/fully dropping the clutch.
I even only have a 6cyl system, so it can only ever cut 6cyl. I still can barely notice it activate as the car cuts in/out 2-6 of the 8 cyl. Also from testing/setting up, I can tell you a LS does not move under its own power with 2cyl active only, so you don't really need an 8cyl version.
It works great in corners. Pin 1st at 5kmh doing a u-turn and having the car not lose traction is VERY DIFFERENT to what happens with the system off.
  • Like 1
Stupid US dollar
My impulsiveness kicked me in the balls with the current exchange rate, and shipping was exxy for what it was at $107US
Meh, as the cool kids say "Yolo, sent it, hold my beer" or something like that
  • Haha 1
Sounds like it's doing the job it's designed to do well.
Can you turn it off if you're in Mexico and want to rip a skid?
Sadly my car is non abs. I wonder if it's as simple as retrofitting some speed sensors or if it needs signals from an abs module?
Yes, you can turn it off and rip skids....in Mehiko
Or for heating up tyres at the drags
Have a google, apparently you can fit sensors to anything really, cost to fit said sensors is ????????
There's a dial that has the amount of slip you want (0%, 5%, 10%, 15%, 20% and off in my case)
So at the turn of a dial near my left knee you can indeed go berzerk.
It just needs access to a speed sensor or something that pulses in time with the wheels and it uses that for it's calculations. Racelogic used to sell a wheel speed sensor kit and a wheel speed sensor version but it was a bit more pricey. I don't think RaceTCS has that but given they label their own item as "Racelogic alternative" I wouldn't be surprised if it shows up soon lol.
  • Like 1
Can you shoot me some info about how you wired it into the injectors and abs
My plan is some stranded CAT6 twisted and sheilded for the ABS
How did you/what did you use, to connect into the ABS/injector wiring? Crimps/solder??? Chewing gum???
For the injectors
Option 1: I'm either going to get 9 different coloured 0.75mm stranded wire for the 8 injectors and 1 earths, then make up a harness with corrugated conduit and heat shrink
Option 2: Get 4 x 5 core 0.75 FVV, 2 x 5 core each bank for my injectors in and out (allows me to keep the same colour wire for the cylinder in and out, and the spare for the earth
Any pics or recommendations would be most welcome
I'm looking at option 1, but I may be missing something simple
Now, where or my wiring tools that I last used 22 years ago?????
Who am I kidding, Jaycar here I come
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
