On 25/08/2022 at 10:47 AM, Kinkstaah said:
Also if you're gonna do that, buying new rims, go 15's or something for more sidewall.
I want matching rims front and rear though, so throwing some DR on my current set is where its at
The smallest the FR1 go is 17"
Unless I go for a totally different set for front and rear, which I don't, because the FR1 meet my bogan prerequisites of wheels
I did look at some 15 x 8 and 15 x 10 rims, but the rims cost a fortune and look way to drag racer for my " it's basically stock" look that I'm going for
On 25/08/2022 at 2:07 PM, Duncan said:
nothing could be more bogan mate, steelies on the back
Yeah, I did try some custom steel "chasers" all round for a while, but ended up hating them and put the stockers back on, gave them to my mate used them on his box trailer 🤣
I do have a set of 15 x 7 "chasers" in the shed, they can fit up to a 255 drag radial, but, I would only run them at the drags, running them daily would be way too "lower class" Bogan and my family wouldn't let me in the door
My family likes to consider ourselves "middle to upperclass" Bogans, hence matching Gold Simmons FR1's or bust
I'd be running the 15s with 255 et street as more side wall. The smaller side wall 17s will really require a softer spring to get it to work properly.
Chuck them on when heading out to the drags and or throw in the boot with a floor jack and change there.
If really wanting a lower 60 ft thats the easiest option.
  • Like 2
Yeah, but I don't want to run them just for the drags, I want to run them during fair weather short cruises, <100km
The only time I would run the "street tyres" would be during wet weather, or long trips away, like down to Goulburn, or interstate for holidays
Having power without traction defeats the purpose of having the power
The Toyo R888R are better than the RS4's, but, it could be better
I'm happy to replace the Drag Radials when required, I should probably get around a year out of a set if I'm using daily tyres for the long drives, the Harley gets used for short trips to and from work
In the end if I get a 11 something I'll be happy, but having traction on the street is also rather handy when push comes to shove
The 255 RS4's didn't cut the mustard
The R888R are better, but.....
No road tyre is worth it. No 17in drag radial will compete with a 15 one with more sidewall. Just wear different rims front rear at the drags. There's the reason everyone does it. Driving on the road with drag radials is shit anyway, unless you are doing massive launches at every stop, they are really only good for launches, and detrimental everywhere else. Going on a cruise with corners in it I would really advise against running a DR on the rear and a regular tyre at the front.
  • Like 2
Don't you have the race logic traction control now? So should be good for traction
We change wheels and tyres for the road section on road trip stuff. Radials aren't fun on long drives.
If you don't have miss matched wheels are you even drive a commoodore?
I get the whole it looks same wheel setup have a go with the 17s and traction control setup should be a big difference.
  • Like 1
Haven't had the RaceTCS hooked up yet, it has been sitting at Autotech because Spiro wanted to do some research first as he hasn't used one yet, apparently he contacted a mate from Haltech, who knows of the RaceTCS and actually rates it
It will probably go in to get fitted in a few months time
And whilst it's good for traction, it pulls cylinders to do it, with better tyres it won't be so aggressive
I drive the VX like it was meant to be driven, it's is a big fat boat for eating miles, which was never designed to go fast around a corner
The whole point of it is to be a cruiser, that will go fast, in a straight line, not a track car or even playing touge with the kids
My driving style is typically cruising in the left lane with the radio on loving life, only with the occasional roll on, or trip to the drags for some fun
As for daily driving with drag radials, on my old R33 I ran R32 GTR 16" Rims with 255/50 16 MT SS drag radials on the rear alot around town, they were fine in the dry as long as you ran at least 35 psi in them, again, not playing touge or race car driver on the street, just cruising around and rolling it on
Memories
  • Like 2
Booked car in to swap out my 2.5" Y pipe and 3.5" single for a 3" Y pipe and 4" single because........noise
I'm justifying it to my myself because rule of thumb math has it not being a restriction under 650 hp at the fly
So I would be irresponsible not to do it
  • Like 1
Sounds more like future proofing for more displacement 😁
How big were your headers again?
On 8/29/2022 at 2:44 PM, Kinkstaah said:
Is the car not loud enough already or
What did you say??
  • Like 1
What did you say??
What?
Speak up!
1 7/8" to 3" flange
Flange...LOL
  • Haha 1
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
