2 hours ago, Dose Pipe Sutututu said:
Good time, will be hard for me to beat you!
Maybe, maybe not, it always depends on the day
Best time of the night?
As many runs as you need?
A bag of delicious hot cinnamon donuts for the victor?
I'll run first then park up till needed, or, WSID closes, whichever comes first.....😜
  • Haha 1
2 hours ago, Kinkstaah said:
.... sorry was that with the MT's or with a regular R888 tyre?
275/40 17 MT's mate
I'll have another play in a month or two and see if I can crack a 10.???
I actually forgot to soften up the rear suspension, and also forgot to press the performance button to let it rev out a little more
Next time I'm going to set up my phone to record everything that is happening on the dash, like launch rpm, shift points, and what mph and gear I'm in at 12? Mph, I'm not sure if I was right at the top of 3rd or it changed into 4th at the line
Also, remembering to hit the trac and performance buttons, loading up the trans a little, slowly "mashing the pedal" is all apparently to hard for me to do, LOL, but, at least I can only get better
If was balls deep fun though
  • Like 3
I'll be keen after All Crap Day, provided my car hasn't exploded or ended back on a trailer/hoist/jackstands
  • Like 1
That's just the game we play mate
I'm now looking at a little vibration at high RPM, maybe the 30 year old flogged out tail shaft?
Smile and wave, smile and wave
  • Haha 1
It cracks me up to no end that you have a fridge in the car! There's something about the thought of hitting the drag strips with cooled pastries in the back that just hits right.
Have you ever been to Patisserie Schwarz in Wentworth Falls? If you are out that way it's well worth stopping by. Proper Western European pastries. It gets a bit busy and not a lot of seating but their baked goods are top notch.
(Context)
  • Like 1
(Context)
Currently sitting under my desk at work running on 240v, it holds my milk and lunch
My milk tended to "evaporate" pretty quick in the kitchenette fridge that everyone has access to, so I needed to take measures
  • Haha 2
2 hours ago, robbo_rb180 said:
Must work with some jackc*nts to have to do that.
Vibration in rear or front?
once that vibration sorted would have to be one of the tidiest and sorted commodores out there.
I feel it is probably tail shaft, it is a body type shake over 80mph, and doesn't get better until under 80 mph
I'm "thinking" tail shaft anyway, I've booked it in to get Autotech to get it up on a hoist and have a good look
Some new rubber tailshaft coupling bushings and a new centre bearing on the 20 year old girl can't hurt anyway, so that may be a quick, relatively cheap, shot gun approach to start with anyway, justified in my mind as preventative maintenance
Preventative maintenance stuff helps me sleep well at night
The Matouks boys would be shaking their heads at this comment. Bipolar R33 gtst recently went 6.49 221mph 1/4 full bodied and still running irs rear end on 275's. I think that's the fastest 33 gtst in the world, also has sunroof. Covers off that record too. Lol.
Yours should do an easy 10 with traction. I know, easier said than done.
Sorry MLR for non bogan content.
  • Like 2
4 hours ago, Dose Pipe Sutututu said:
I could thrown on Simmons on the car, white walls dis dat, instant @The Bogan approval.
Nope, Skylines need to run stuff from J to keep the "ricer" look, like vented bonnets and neons, and 3 ft long exhaust tips
Yes, I know and apologise for using the word ricer, but you cannot be a true bogan in a Skyline, as you cannot be a ricer in a Commodore
Sort of like how rednecks drive American cars
And fat old white guys with arthritis ride Harleys
I'm still out on the classification of the R30-31 Skylines though, they are a sort of fusion blend of bogan and rice.....Bogice????.....Rigan?????
I apologise to no one
But love youse all
  • Like 3
  • Haha 1
But love youse all
I have very long hair and have been rocking a chopper mustache for movember.
Bogrice sounds good, when you have a succulent Chinese meal from a dodgy food court behind Woolies CBD and your bog contains rice.
  • Haha 1
8 hours ago, GTSBoy said:
Typical R31 are from a stratum somewhat below you common or garden bogan. I think feral is the best description.
Maybe I should of got one of these before they commanded drug money
https://www.carsales.com.au/cars/details/1989-nissan-skyline-gts-hr31-manual/SSE-AD-7439094?pageSource=details&id=SSE-AD-7439094
Just dropped the car off to Autotech Engineering to diagnose the vibration I'm getting
Hopefully just the tailshaft couplings or centre bearing
They are going to stick it up on a hoist and have a good look and see if the couplings or bearings are showing wear, if they looks alright they will stick it on the dyno and try to replicate it and go from there
It never happens on the street doing 110kph on the hwy, or when I'm giving it some beans, but, once the car hits around 140kph at the strip it starts to vibrate and increases all the way up to when I back off at the line doing 200kph
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
