15 minutes ago, Duncan said:
I always thought 6,000rpm was when boost was meant to arrive, not when revs run out?
Full boost (7 psi) arrives just off idle, excellent for a street car with visions of grandeur
  • Like 1
New knock off headlights are not storm proof and have got some condensation happening
I'll pull them in a while and try and do a smoke test to find where they are leaking
They currently have the caps removed to try and dry them out
Insert sad face here.....
In other news the car has almost run up to 150k km, so the LS1 is basically just run in...
Check the drain plugs aren't blocked on the lights mark. It might be trapping the air in there.
Also, at 150,000km on the clock, time to put it on blocks. That's your half million dollar retirement package in a couple more years :P
  • Haha 1
Dropped a deposit on a 4" in/out Varex muffler
Do I need a 4", probably not, LOL
Also got the remote delete for a momentary switch coming in the mail
Thinking about it after I hit the buy now button, I probably could have used one of the rear windows switches, door
Meh, consumers must consume 🤣
Car had a miss only when nailing it, so I changed the plugs, that didn't fix it, so looked hard at the leads, they "seemed" fine, sooooo, dropped it off to Autotech to see what's up
I'm guessing a coil, or lead, or wire, or "something" else all together
Car was still driving fine cruising on the street or hwy, just not when I mashed the loud pedal
Stupid car..... how am I meant to show the local cars my tail lights.....
But you said cruising slow was what you're all about. Now you can do it dropping cylinders and popping and banging. Sounds like an upgrade!
As an aside, LS's are hard to even notice you're running on 7cyl for a month or so. Been there myself 😛
  • Like 1
A lose wire and a dodgy lead was the cause of the misfire, car is back to loving the loud pedal
Still waiting for the 4" Varex to turn up, the X Force toggle switch has already arrived, but as yet I'm not certain where it is going to go, somewhere that is easy, quick, but still out of the way, maybe the fuse box cover, maybe in the centre console?????
I also need to work out how to get the wiring from the Varex inside, hopefully there is already a grommet in the boot somewhere handy, otherwise it's a big drill bit and a grommet
  • Like 2
37 minutes ago, The Bogan said:
I don't want to "danger to manifold"
So nope
but but you don't have a 4 cylinder N/A making turbo whooshy noises with a laptop connected to it
  • Haha 1
52 minutes ago, GTSBoy said:
This is obvious. Put it where it will get triggered by about 50% throttle!
It is a monetary switch, so push the top or bottom to open or close
You can get a smart box that works on a phone app to have open 25%, 50%, 75% or fully
You can actually get an ODB2 box for a Varex, which will (yes, live) link into to engine parameters to open. So it can be automatically set to fully open at 50%+ throttle or whatever variable or combination of variables you choose.
  • Thanks 1
I've got a ODB2 scanner that monitors IAT, and stuff, a up/down button is simple to work and easy to install
What I really want is a Haltec ecu thing is that monitors/adjusts everything, but, for the car it is overkill and costs way more than this old rooster can justify to purchase, wire in and then retune
Maybe if I win lotto 😒
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
