On 5/7/2023 at 8:27 PM, Duncan said:
sorry Mark, I lied, it does get cold here.
<scottish> just had to walk home, uphill, in the snow </scottish
Have you thought about putting the washing machine inside so you're not also doing the washing in the snow? 😛
Just dropped the car off at Fineline to cut in the VN Group A bonnet bulge, they are going to see how it looks bolted and glued on first, then "maybe" mould it in, then back to standard height OEM engine mounts, the front Holden badge on the bonnet is also being removed and the locating holes welded up
Should be back to me in around a week
Which ever way Fineline do it it will be quality work, I've had alot of work done by them over the years on my cars and bikes, it has always been excellent work and paint match has always been spot on
Hopefully I don't hate it like the VK reverse cowl that was on before, the VK reverse cowl was too in your face, it lost the windscreen squirters, and was to boxy, the VN buldge is much more low profile and rounded which "should" suit the VX's rounded lines better, but, "failure is always an option when it comes to my good ideas"
Like this, only a bit more towards the front to keep the windscreen squirters and get clearance around the front of the blower and throttle body>
  • Like 1
Impulse buys away
So much for stock engine mounts, these have a larger softer bush than the Tuff Mounts, so less NVH that now, and are OEM height,.......... and are "apparently" unbreakable
Was recommended them by a guy at work who has been running them for years
Screenshot_20230524_215532_SamsungInternet.thumb.jpg.1b526163d846265b6eab08bc1689011f.jpg
Super happy with the result
Ample clearance to use OEM height engine mounts
I just need to put the Carbuilders premium under bonnet liner on to finish the "it's stock" look....... under bonnet 🤣, and fit the new engine mounts, then off to WSID for some more fun
20230529_161956.thumb.jpg.acd0f3e844142a7144de0d0cd98b16de.jpg20230529_161949.thumb.jpg.d29eddcc8a51371d88b94a48852d9fa3.jpg20230529_144030.thumb.jpg.35ce228393b0f0f146c5ee3bc0ff153e.jpg
  • Like 3
Gave it a wash and wax to clear a week or so of dust off it
All ready to drive down to Goulburn tonight to get covered in insects
I hate driving down to Goulburn at night, Kangaroos and Wombats, fair warning, get to your beds and off the roads
That actually looks pretty good Mark!
I'll be honest, I was curious how well it'd work on the VX bonnet!
The no badge on the front smooths it off too, but defeats the "it's stock" look a little. I guess you have to have some trade offs, right?! :P
I think for me, the only way you could make it look more stock, and a bit more streamline, would be to blend the bulge all the way to the end of the bonnet near the windscreen, and if it was still a little high, make the line of the windscreen edge "rise up" near it. But that's a lot of customising on a bonnet, for something that looks pretty darn good, and fits your purposes!
also, I'm not sure it needed a wash and a wax Mark, it was already the shiniest VX I've seen in a long time! Ha ha ha nice work on keeping her tidy, while also playing with mods!
  • Thanks 1
So, the new MACE unbreakable engine mounts are in, the engine is now back to standard height, the driveline-(read: engine/transmission/tailshafts/diff) are all nicely aligned again to the correct angles of the dangles
Everything fits nicely "under the bonnet", even with room to spare, driving back to work was a dream, no more NVH from hard poly engine mounts, and as was right in the world
Until..........I gave the beans hard
Harrop designed the blower to fit under the bonnet and have clearance everywhere, the top of the hat had heaps of space, and the rear belt drive had enough room to move up when the engine torqued, but........not when you add 10mm thermal spacers under the hat
What happened was the allen key bolts that hold the rear belt idler on, and a lip on the firewall met and had a issue with each other trying to occupy the same ground, thus war ensued as they both fought to hold the same ground, noisy screeching war, Mark got scared, backed off, and panicked
Apon inspection it seemed all good, maybe 10mm clearance between the allen key bolts and the lip on the firewall..... until you gave it the beans hard and the engine torqued up about 11mm to introduce about 1mm of the top of the allen key bolts to the lip on the firewall
Luckily, Tyson had the correct "firewall tuning" tools on hand for me to use, a big bent 3 foot pry bar, that convinced the lip on the firewall to move a little (probably 10mm) out of the way
So after careful tuning (you cannot really see where we tuned it), we had an ample amount of "no man's land" so that the waring parties would never again meet for hand to hand combat
Testing was conducted again by giving it the beans hard from various roads speeds on the R888R's with great success
Further testing will ensue as I'm going to try and hit WSID next Wednesday and see how it likes doing a big skid then getting stalled up on the foot brake and leaving hard on 275 Micky T drag radials on a sticky surface
Note to self: I must rummage around the workshops at work and find a typical tuning tool to take to the drags with me, if, on the off chance, any further "tuning" is required
Winner winner chicken dinner
How fun is it modifying 🚗
  • Like 5
Ground hog day
Spent "most of the day" giving the car a full detail, started by putting it on stands and cleaning the under body and inner guards, and wheels, then stripped off all the old wax, then washed and polished a few little micro scratches out, then "lovingly" applied some Meguiars Gold Class Carnauba wax, by hand, using the warmth of my hands to soften the wax then smearing it "lovingly" into the paint (probably weird, but it works so well)
After letting it cure for 1/2 an hour, enough time to clean and vacuum the interior, I buffed it off with about 10 microfibres, the paint looked excellent, I love the way wax gives that deep look to the paint
After it was all smick I stood back and bathed in all of it's heavenly glory
Then took it for a cruise, lovely day, car runs a dream, perfect.......until it started to rain on the way home
22 hours ago, The Bogan said:
Ground hog day
This is why I wash my car after it has behaved. Otherwise you wash it, want to drive it, and then drive it 500km through bugs and all sorts of crap.
(and/or just leave it dirty)
  • Like 1
@Kinkstaah
I was sent this as the table in HPtuner to look at
From your experience with HPtuner, if a tuner "tickled" this in 1st and 2nd to "lower power" a bit would it help??
Cheers
3 hours ago, Kinkstaah said:
Sent what. Nothing? (I don't see the thing to see :D)
LOL, I'm an idiot
This thingie, he said you can modify stuff in HPtuners to lower power in gears/RPM via timing
A little less power in the low to midrange of 1st and maybe 2nd won't be missed as it now just wants to overpower the tyres with anything more than around 50% throttle on street tyres and around 75% throttle on drag radials
If I could lose a little bit of power down low on drag radials to minimise wheelspin on drag radials I believe that would help my 60ft
Also wouldn't that help with mechanical sympathy IRT low piston speed and boost??, although, whilst my boost is only at 7 psi, it pretty much makes it just off idle, hence all of the torques it makes at around 2k RPM
What's your opinion on this table thingie?
Cheers
Yes you can. It removes timing given your car is setup with an Auto box (and presumably it is configured to use it) and came with it from the factory, so all of the wires match up. The car does a torque calculation in the ECU and uses it to determine whether it is going above it.
It will require tuning, so what the computer THINKS is X nm of torque actually lines up with how much torque is blowing the tyres apart. In other words, it is gonna be hard to tune this because you don't actually know what value you want in there, because your engine may think it is producing 342NM, but is actually producing 550nm, and 474 actual nm is when the tyres give way, if you catch my drift.
This will cost more than wiring in the TC system you have and work less effectively. I believe (my car is manual so...) this leverages the stock TC system in the car to change how it pulls timing to regain traction. Assuming that is all still connected and plugged in and working for your OEM car, it could be a feasible solution if you get all the data out of the logger to determine how to set this table (s) right.
  • Thanks 1
I just sent Autotech a email to revisit getting the RaceTCS installed
In the end, because of my lack of any wiring skills, and fear of burning the car down, if they cannot, or won't do the job, then I will need to revisit everything again
Wish me luck
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
