  • 4 weeks later...
4 minutes ago, stellarimports said:
What were your voltage readings for empty and full? I am about to set this up with my powertune dash and platinum pro in my R33.
Check the previous page for the readings I had. I thought they seemed low but the other members had similar readings.
I used those and everything seemed fine, then some reason they weren't.
After a day the senders reading were 0 (on both the OEM and Haltech conditioner) from what I personally got from pulling the sender.
I went back to the voltage numbers from the how to write-up article and the level read numbers and close to the level I had which was nearly full.
From memory the article number were 0.27 full/1.31 half/2.53 empty.
I was pissed cause all the work to pull that sender out and get the reading and it didn't work as planned for me. I cleaned the sender rail and everything. Idk why it reverted to the higher readings.
So I'd say to u, use both sets of reading and see what works for u.
To add I think the haltech sender died. Maybe got fuel in it. I will check to see if it works again after my work trip, but the oem seems to work better imo.
  • 1 month later...
Hey guys,
Im having an issue with the fuel level on my IC-7 too.
I go into input calibration and try to input a range of values say for example 2.4v empty and 0 volts full. i then click apply and it automatically changes these values to 0.924v empty and 0.16 volts full.
It also wont let me disable the pullup resistor either. i tried disabling just to see if it made a difference.
I filled my tank up to the brim and ive done about 120km's and my tank still says 100% full. so either my car is now the most fuel efficient car in the world or theres something wrong.
I'm using AVI input 1 sensor pin 18 with the 90-0 ohm fuel sensor channel.
Anyone have any ideas?
Car is an R32 GTS-T with a hlatech elite 2500 ECU - which shouldnt really make any difference i dont believe
Edited by DaymoR32
2 hours ago, DaymoR32 said:
Hey guys,
I have a Plat Pro. i didnt have issues it any auto correction of the values or the resistor button being locked out
the resistor button isnt locked out so to speak. i just change it on the drop down to "disabled" then click apply and its enabled again if that makes sense
So now I'm having the same issue as you. My sender stopped reading the other day as the full value changed. It doesn't set when pressing apply
I dont know why. I just did it out the blue
so is yours saying 100% full aswell? what voltage values have you used for full and empty? and did you put more than 2 columns worth of data in?
I've tried having 2 columns. i.e 2.4v - 0% & 0v - 100%
Then ive also tried 6-7 colums with 0, 20%, 40%, 60%, 80%, 100% etc
It still reverts back to two columns and random values when i click apply
Full was 0.27 / half 1.31 / E 2.53
Just full changed.
I kinda fixed it. So I have a haltech fuel sender conditioner still wired. I think it died from getting gas in it from pulling the sender, but I had it wired up still. I pulled the power wire off for it which seemed to have made the OEM sender signal stick to full. Once I put the power from the conditioner to the battery, It started reading 15gals.
However the ICC software still reads 0.01 and revert while trying to change
Just full changed.
hmmm, i dont have a haltech fuel sender conditioner in mine. im just taking it straight from the fuel level wire that went to the original dash.
I originally had the fuel going into pin 21 as per the wiring diagram but that just didnt work at all and could not be calibrated for some reason. theres sesor and diagnostic for each avi input apar from on avi 4.
I really dont understand why its not working when it worked fine on the Racepak IQ3
Mine is set to pin 18. Mine worked fine as well. Idl what to make of it.
This calls for an email to Haltech
one more thing that i havent tried, is modifying the dash when its not plugged in. basically load your layout from the dash > unplug > change settings > plug dash back in > send to dash.
Maybe that will work....
I tried that too.
Even loaded my old file from January. Still reverts. And I just updated the firmware today so i know it wasn't that
  • Like 1
14 minutes ago, SLVRBAKSLPZ said:
I tried that too.
..... It may be the new software update.
I loaded the new update on my laptop a week or two ago. I didn't use it til today. Tryna change it offline with my old file and it's not saving settings.
I'm emailing Haltech now.
thats another possibilty as ive only used the latest haltech software!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
