Hi all,
Looking at getting my first skyline and why not start with an R33 GTR...
I had a mechanic check out a car that’s as generally great but has 2 potential issues, rust in the body by the jack point on the driver side and an unusual join point or weld under the door jam on the same (driver) side. Pics attached.
can anyone tell me if the rust looks bad? Or if the unusual weld is a factory thing (the owner said his other GTR has the same thing)?
TIA
JC
https://www.sau.com.au/forums/topic/480234-any-rust-experts/
The rust  - in the pics - only looks minor.  More could be hidden away.  The jack points are always abused, you need an original jack or an adaptor plate on your jack to avoid damaging the jack points.  I made up a plate to prevent further damage , but my car had already been molested.  The 'unusual join point or weld' I can't really comment on except to say its hard to know where on the car it is from the photo and that it looks serious.
Guessing it is on the sill near the trailing edge of the door?
If that was an R32, it would be under the driver's door scuff plate about 40mm from the back end of said scuff plate. You can't see as much of it on a 32 without removing the scuff plate, but what I can see of mine is that it about 40x better than the pictured one. As the pictured one is on an R33, I don't know why it appears to be separate from where the scuff plate is. Regardless, it looks like pox. The seam filer should be smooth and even and the paint should not look like it was applied with a goose's arse.
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
