Hello, names Kyle long time reader of these forums as ive been looking for a r32 for a while now and I am finally a happy owner so thought id make an account haha !
Here is my
89” R32 gts-t (RB25det NEO)
Few basic modifications/upgrades
coil over suspension, exhaust, fmic, injectors, coils, TD06-20G Kinugawa turbo w/ external gate, powerFC having car tuned in the next week as it is running slightly rich and will have some numbers to share?
Edited by KyleArcher
  • Like 2
https://www.sau.com.au/forums/topic/480278-qld-r32-rb25-neo/
  • 8 months later...
So a lot has happen since my last post from upgrading parts blowing and replacing the head gasket fitting a new link g4x ecu and all the sensors with a flex fuel tune to come I look forward to posting more on my build progress here !
First off I decided to give the car a run at my local drag strip on an open test and tune ran great for the most part with a best time of 13.3sec 1/4mile and a 2.2sec 60footer  I was getting a lot of axle tramp and not a lot of grip, after many passes I noticed my gear stick slightly on the right side and hitting my park brake I suspected engine/tranny mounts were shot.
I attempted to adjust the coil overs and found they were seized in position I have taken all corners apart completely and rebuilt my coilovers along with replacing the old crusty LCA’s with adjustable Hardrace parts also upgraded my brakes to a slotted style rotor and gave my callipers a fresh coat of paint still need a wheel alignment but wow this made a difference in handling and the all round feel on road.
Done some research on here about axle tramp and here’s something that worked for me, I ordered some rear subframe collars from gkteck and after fitting them the rear end was tight and the tramp issues I had under hard acceleration/launching were pretty much non existent.
So I had planned on upgrading my ecu for a while and ended up pulling the trigger, I put in my order along with all my sensors that I required for the setup as well as running a flex fuel tune 98/E85 blend along with a 24tooth trigger sprocket to help with rpm readings, all was going well but upon a leak down test and running the car the company I had gone with and myself had realised white smoke we checked the cylinders and found cyl 6 had a possible head gasket leak with both oil and coolant entering the cylinder.. oh no 🤦‍♂️
I ended up trying to save a bit of money as I had just invested into the computer and other parts so I decided to setup a spot in the garage and get to pulling the head off this was a great experience learnt a lot about my motor and got to clean up slot of the engine bay along the way !
When I removed the head it was a perfect time to change the engine mounts which I found completely to disconnected to the chassis lol 😅 I replaced the engine mounts with hardrace and also used a solid gkteck transmission mount.
I went with a Gates timing belt kit, genuine water pump and thermostat and also decided to replace my a/c compressor as the pulley was seizing up and making a lot of noise.
probably a lot I missed but just received the new crank pulley today and should be able to finish the assembly this week and be able to take it for it’s new tune ! Can’t wait to find out what she makes and to go for a drive thanks for reading if you made it this far.
edit: Also fitted some type M skirts and modified a wrx front lip to suit the gtst front bar still need to get skirts painted.
  • Like 1
On 19/01/2021 at 12:13 PM, DaymoR32 said:
nice bit of progress there mate! M Spec skirts really finish the car off,
are the skirts and rear pods from KMAK Aero? whats the fit like of the pods?
Thanks mate looking forward to what’s next, yeah the kit is from KMAK pretty happy with the quality and fitment one small air bubble in the skirts that chipped away where they hadn’t pushed the glass into the corner of the mold but a easy fix with a bit of filler, most the mounting holes lined up with the oem guard liner screws with the exception of a few extras I drilled out underneath also one on the pod corner to pull the gap in could have used a adhesive but wanted a solid fit (:
cool thats good to hear, im holding out for some oem plastic ones, but may have to bite the bullet and get fibreglass!
  • 8 months later...
Ok guys been a minute but thought id update my post.
I ended up getting the head on after my head gasket failed on me and all was great for a few months and then i heard it… a nocking noise coming from the motor bottom end bearing spun i am yet to look into the motor to give it a more in depth inspection but going through my link i had a oil pressure drop anf i think this is the cause.
Anyway i ended up snagging a reconditioned long block to throw in and start fresh i just pulled the motor today and am dressing everything up to go back in going to try tody up as much as the engine bay as possible to make it a little cleaning along with a new intake plenum from otaku garage, i will be fabricating new intercooler piping to suit.
Enjoy the photos this new motor looks badass 😄
531B74BB-7EAF-4EDA-8513-8A4CE879A5C1.thumb.jpeg.7a07d134de6f86de394d963c86680566.jpeg7616436F-09E2-4E8F-8C7A-BC828B16F67C.thumb.jpeg.a35897671f5d06a7f19d309358b0bcfa.jpeg56C2889E-5960-418B-B265-C5BB287E4FEA.thumb.jpeg.a4eb129aa3b9d58fec17fb7b05e8ffe9.jpeg
@DaymoR32 100% mate i done some research before going with this one, i think a few brands sell them of as there own and yeah the face of the flange is not the best can see marking from the tool used
also a few bits in the kit like the head of the bolts for iac valve were to big for the countersunk holes and did not sit inside the mating face of the flange only a problem for neo’s as far as I’m aware
other than that looks great full peno on welds and apparently otaku garage pressure test each plenum but not sure how true that is hopefully holds 20psi with no issues 🤞🏼
  • Like 1
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
