Hi again Matty. Yes same, rail upgrade no. Denso based 10.5 or 11mm injectors all fit into the standard rail. Nearly all of these older direct fit injectors are all made by Denso - Nismo, Power Enterprise, Tomei, Sard, Blitz
I suggest you go bigger than 550cc though
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932190
52 minutes ago, Matty George said:
Ha well loyal to Nismo??? Suggestions?
What? Nismo are the same shit as that Sard shit.
Bosch, Denso, Siemens et al have all been producing newer design injectors over the 20 years since those Sards were state of the art (if they ever were). Any Bosch EV14 based injector is going to be a millions times better. Shit, even an EV6 based injector will be nearly 2 decades newer tech.
There are hundreds of vendors selling EV14 or equivalent Denso (and other manufacturers) injectors with conversion plugs, rail spacers, and flow matched sets. Here's just one example in Australia, at Goleby's https://www.golebysparts.com.au/products/rb26-bpp-fuel-rail-kit-bosch-1000cc-injectors-fpr800-fuel-regulator?variant=31930369081453
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932204
I run the old Denso 700cc on the 33 and they are at about 75% duty cycle at 330kw on 98. On the 32 I went from the Denso 1000cc to the Bosch EV14 1550cc - heaps better.
Get the Bosch EV14 1000cc as Gtsboy said, best idea
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932206
My advice is if you have a lazy tuner, don't get the Bosch 1480cc aka 1550cc aka 1650cc (they're actually 1480cc but everyone likes to call them the 1650cc).
Their true code is 0280158334
Reason why I suggest against it if you have a lazy tuner? they're sensitive to fuel temperature and if you don't build out that fuel density vs. temperature vs. ethanol content table they will run like shit.
Most tuners don't bother with this, however a silver lining is that if you have a Link ECU that table is pre-defined.
Also Nismo injectors, FPR, etc. are overpriced and dated. It's 2020 no 1999, imagine trying to use Instagram to look at instahoes on a Nokia E61.
  • Like 1
  • Haha 2
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932209
1 hour ago, Matty George said:
Thanks men... I understand the Nismo sate older tech but they still do the job. Yeh Bosch were my other option which I’ll look at getting from kudos.
The Bosch ones from Kudos are the 980cc / 1000cc ones, not sure why they are advertising as 1250cc. Same thing as from Golebys, EFI hardware, EFI solutions, NZEFI and so on.
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932214
Dick measuring contest, false advertisement at 4bar base pressure. Shortfall with running high base pressures is that you put enormous strain on your fuel delivery system to keep up.
4 bar base + 2 bar boost = 6 bar of fuel pressure. As you add fuel pressure, flow rate drops & current draw increases. Both increasing fuel temperature and reducing fuel density.
  • Like 1
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932228
You can get a flatter flow rate vs fuel pressure curve and a flatter fuel pressure vs current draw curve with brushless fuel pumps these days. I believe the R35s run 3.5 bar base fuel pressure to improve atomization. Everything is a trade-off.
6 hours ago, TXSquirrel said:
If you want to stay true to Nismo/OEM and want modernized injectors, just get R35 OEM injectors.  570cc and very good atomization.
I would say this is the way to go as well. Just keep in mind that fakes are everywhere, be very careful to source genuine parts if you go this route and get your injectors characterized if you can for various offset tables in your ECU of choice. Other thing to think about is whether you want to run E85 or not. If you do I don't think the ~550cc class injectors will flow enough. You want closer to 750cc in that case. Closest things that are actually modern injectors are either the SARD 850cc high impedance injectors or the Bosch 980cc mentioned already in this thread. The SARD injectors are Denso parts, just not sure what the OE application was. Bosch 980cc was originally used in some Renault I believe.
I don't recommend ID injectors, maybe it matters if you want accurate/repeatable fuel delivery down to 0.2ms of effective injector open time or 10 bar of fuel pressure or whatever but their injectors lack the diffuser plate used in most modern injectors which causes the spray to go straight into the divider walls between the valves, which increases the amount of wall wetting and makes it harder to get transient fueling nailed down as a result. They're optimizing for an extreme that doesn't make sense if you want 300 kw with -9s.
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932249
Haha yeah there are so many fake R35 injectors out there.  However R35 guys junk them pretty much as soon as they take delivery of their cars, so just contact a shop that works on R35 and they probably have a pile just sitting and collecting dust.  I got mine for $70 USD, plus I paid another $110 USD to have them cleaned and flow tested, not bad for a set of barely used quality OEM injectors.
Also 570cc is the flow rate at 3 bar, but they are actually designed to run at higher base pressure, so there is still more potential if needed.
https://www.sau.com.au/forums/topic/480529-rb-26-injectors/#findComment-7932258
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
