Order the proper off set ones from Nissan, but get some new refills from SCA to tide you over...
Found some close ones at Autobarn when I had my Skyline, and threw away the old ones, before I realised that the new ones were a close fit, not an exact fit, and did not have the offset mount, so had blades that were 1cm to the left of where they were supposed to be... ?
Won't help you if you're in a hurry to get replacement wipers but unless someone has found the Australian equivalents here, I have Bosch Icon (complete arms) on mine, which I bought from the US via eBay. They are mounted in the opposite direction of what they were intended for, given the RHD vs LHD thing, so they look a little oddly placed. Bugger it though - they work and they work really well.
They just perform better for longer compared to all the usual blades you find at our typical retailers in Oz. They have a funky design to them to combat winds at high speeds so that the wind isn't fighting against your wiper motor on the freeway but in reality, you'd have to be doing some seriously illegal speeds or driving through a hurricane to have that as a problem. That, however, is why they look a little oddly placed when upside down.
Fair question but I read this and figured if it really is the case, then that's the way I'll go.
https://f30.bimmerpost.com/forums/showpost.php?s=b24f005f56e46e74ecc0926c5b0349d9&p=19652599&postcount=13
I know it's dangerous to take the word of a BMW driver but I like to live on the edge sometimes.
I'm a BMW driver now ?
I can't see why you can't just bung in ICON or AeroTwin. Hell since it's a Nissan I'm assuming they have J-hook wiper connection (easy peasy to change).
Because I haven't seen any Bosch Icon wipers sold here in Australia, only Aerotwin. The Icon wipers are made for LHD instead of RHD. Replacing them is definitely as easy as you describe but their orientation is a bit odd for the reason I explained before about the funky asymmetrical aerodynamic design.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
