DONO Posted August 1, 2020 Share Posted August 1, 2020 Does anyone know of a fuel pump that I can "directly" replace the factory one with for my N/A r33 GTS. Yes I know there's upgrade kits for more pressure etc, I'm not looking to make power I just want to replace the old pump without messing around with wiring etc, just want to direct swap it for a new one whether it be oem or aftermarket that direct fits to original bracket/wires. Cheers Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/ Share on other sites More sharing options...
Murray_Calavera Posted August 1, 2020 Share Posted August 1, 2020 Just so we are on the same page, you are going to pull out the fuel pump yourself but you are not prepared to join 2 wires? Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/#findComment-7937356 Share on other sites More sharing options...
DONO Posted August 1, 2020 Author Share Posted August 1, 2020 For me it's more the idea that, it's literally wiring that's going to be sitting in the fuel tank, and the idea of messing that up and causing a spark isn't a pleasant thought. The labour of doing the pump isn't a problem. Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/#findComment-7937357 Share on other sites More sharing options...
GTSBoy Posted August 1, 2020 Share Posted August 1, 2020 Do not worry about sparks in fuel tanks. 1 Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/#findComment-7937358 Share on other sites More sharing options...
Dose Pipe Sutututu Posted August 2, 2020 Share Posted August 2, 2020 There's too much fuel vs. oxygen for combustion to occur. You could put a spark plug in there connected to your ignition system and it won't ignite. Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/#findComment-7937360 Share on other sites More sharing options...
KiwiRS4T Posted August 2, 2020 Share Posted August 2, 2020 Walbro GSS 341 or similar Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/#findComment-7937406 Share on other sites More sharing options...
DONO Posted August 2, 2020 Author Share Posted August 2, 2020 9 minutes ago, KiwiRS4T said: Walbro GSS 341 or similar all good I've ordered a GSS342, and will install it once it arrives 1 Link to comment https://www.sau.com.au/forums/topic/480871-direct-fuel-pump-replacement/#findComment-7937408 Share on other sites More sharing options...
