I am in the process of building an rb2630 combo. I keep getting conflicting reports about the strength of the rb30 crank. There's plenty of examples of rb26 cranks spinning past 9000rpm and making a 1000hp. I know the rb30 has a longer stroke but does it really effect the strength that much?
I have had two well known workshops tell me that you can't spin an rb30 crank to 9000rpm and it won't make 1000hp.
Rips (love em) said, no worries. Machine, balance, grub screw and it will do it easy.
The block will use a prp  race/caps combo and an ATI balancer to help keep things in place.
What experience have people had with standard rb30 cranks?
Edited by khezz
https://www.sau.com.au/forums/topic/481174-rb26-vs-rb30-crankshafts/
Are you aiming for a rev limit or power/torque output?
The key difference is not so much the longer stroke, but the taller block. This means rb30 block has a better rod/stroke ratio which is more efficient. RB26 block, particularly with a big stroke crank leads the piston to rock around in the cylinder way more.
Yes, longer stroke (which ever block) gives larger capacity but more piston speed for the same rpm which is theoretically a downside (nothing for free in physics)
Having said that, I don't have a 1000hp RB30 or a 1000hp RB26.....neither of mine make more than about 600hp which is pretty tame these days. I would like both to last more than a few events though....
  • Like 2
I’ve got a built 26/30 with a 68/70 turbo, last tune (with the new head setup) which is shimless set up, 1mm oversized valves cam tech 10.8mm lift cams, etc, was spinning to 8500rpm. Tuner said it would of revved higher but he capped it there to try to preserve it (somewhat).
I’ve also heard conflicting information, some people say they are not safe past 7500rpm, others say they constantly rev to 8500+ with no issues.
as for power, mine is making 580ish kw at the hubs, and there are plenty of examples of stock crank 30’s making 1000+ hp, but how long will it hold together?
Ill let you know when mine lets go! Lol
Goal is to build a car that can be daily driven on 98ron fuel. Be able to run low 9s and go past 300kmh (once my balls grow big enough) at racewars on e85. For street I need responce/drivability. For drags I need outright power and for speed I need revs. Similar to what motive did with their r32 but better. Head will get the full treatment from Rams. Yes, I could go billet but I just can't see an extra $6000 value in 200cc capacity. I am not aiming for 1500hp+ either.
Edited by khezz
It's about piston speed, your RB30 crank at 9k rpm has 17% more piston speed and load due to the increased stroke. Granted this is helped somewhat by a superior rod angle and ratio from the taller block, but you are still putting the additional load through a bearing with the same surface area.
Use RB30, more boost, less RPM
  • Like 1
I've been given some more insight as to why some people are hesitant. Aparently once you get to 8000rpm, the crank will start marking bearings. Some workshops try to get around that by increasing clearances or keep the revs to 7500ish.
I might have to just bite the bullet and go billet crank.
6 hours ago, Komdotkom said:
A billet crank won't make any difference unless you are going for larger journals and wider big ends to provide a greater surface area.
You could just buy a 2JZ....
Barra the world
On 23/09/2020 at 7:44 AM, Komdotkom said:
Back to the RB30 crank, some interesting comments from Lewis engines, make of it what you will:
"Every second phone call involves a discussion on RB pump failures. It is a dilemma that faces the unaware RB builder but can be addressed in several ways.
Basically the 6 cylinder inline engine is not a balance friendly item to deal with at high rpm. The crankshaft harmonics through the inline 6 crank are inevitable and increase in magnitude as crankshaft stroke increases.
This is no new engineering fact but has to be dealt with and manicured as per each individual combination and customers budget.
The Nissan RB engine will go 'past' or 'through' its harmonic periods very quickly and this will interprate the success or the destruction of most combinations. Some turbocharger combinations will find a huge ammount of rpm per time and these are the 'oil pump killers'. The cranks especially the long stroke RB30 will not be happy in these situations. We find in most race /high rpm engines to stick with a 25 or 26 stroke and when using the RB30 to be limited to max rpm of 7500rpm.
When using an RB30 a constant check of the balancer bolt tension is necessary.The first sign of crank harmonics and too much rpm for a combination, is the loosening of the harmonic balancer bolt in operation. The bolt must be done up to 400nm. This cannot be achieved unless the flywheel or crank is held with appropriate tools. A knocking type hammer or torque wrench and car in gear WILL NOT achieve sufficient tension."
Darren doesn't appear to be saying the crank won't do it (well implies it saying "won't be happy"), just more pointing out the extreme harmonics that are created and the effect of them when going past 7500rpm with a 30 crank. I know my Nitto 2.8 crank came with a balancing test report of being tested in 1000 rpm increments to 10000rpm, and would expect their 3.2 cranks to be at least tested to 9k rpm.
5 minutes ago, khezz said:
I wonder if the new oil drive systems or an external oil pump would help the issue. Great point that most people (me included) would have missed.
How is a different oil pump drive or external pump drive going to stop harmonics?
  • Like 1
  • Haha 1
It won't. But the previous post seems to suggest that oil pumps get damaged because of harmonics before bearings. If oil pump stops pumping, so does the rest of the motor soon after.
14 hours ago, Old man 32 GTR said:
Nitto rate the 3.2 to 10000rpm
Yeah I know Nitto "rate" the 3.2 to 10000rpm and they "rate" the 2.8 to 11000rpm. As my 2.8 crank came from them with test results balanced up to a confirmed 10000rpm, I bet the 3.2 is only "tested" before delivery to 9000rpm to be safe, knowing realistically no one is spinning a 3.2 past 9k and a 2.8 past 10k.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
