With RBs pushing power further and further past 1000hp the demand on a gearbox is ever greater. 10 years ago a 1000hp transmission would be considered unbreakable. Now, with the cost of power parts going down and quality going up, the same person who could afford a sequential 10 years ago would be aiming for a number far higher then 1000hp. Keeping the cost aside and keeping dedicated drag boxes out of it (would love to see a thread on Liberty and Jericho transmissions)
Are transmission manufacturers keeping up?
What is the strongest sequential out there?
Why do you think/know so?
I am leaning towards the Hollinger. Been around for a very long time, very widely used in motorsports. Seems to be the only one with straight cut gears which eliminates sideload.
https://www.sau.com.au/forums/topic/481213-strongest-sequential-and-why/
The Holinger sequential for GTR uses helical cut gears, as does PPG and OS 88. Samsonas and Albins use straight cut
I think most would agree Albins would be top of the food chain
You're right, back in the day, most of the GTR's though were either 2.6, or 2.8 only. RB30's werent THAT common.
I was in this exact boat when planning for a gearbox. I went with a 3.2 route. I sussed out all my options and talked to a tonne of people around what options there were for GTR's(excluding auto's here):
* Getrag 6 speed
* Gearset
* Sequential
Personally, I wanted peace of mind hence why I didnt go for a gearset or 6 speed. I mean, by the time you've done either of those 2 options you wouldn't get much change from 15K right? Plus, I dont know how long they would last with the fat torque of the 3.2...I also scoped out the sequentials out there, and in the end I went with the Albins as to me it seemed like the pick of the crop(Not saying the other Seq manufactures are shit, but its just my opinion). Plus, the Albins kit literally comes with everything minus the clutch.. no faffing around looking for tailshafts/transfer cases etc.
I have a Holinger and love it, I bought it a few years about now circa 2015
however Albins and Samsona's seem to be the pick of the bunch these days.
Particularly now the albins can slot straight in without panel beating and the adjuster gear to tweak ratio's is very convenient and samsonas seems to put up with the beatings
I was under the impression you could get either, as the Holinger GRA-6N box for the group A R32 cars were straight cut, and was essentially the same ?
Anyway I would echo above - Albins all the way. Compared to Samsonas they have definitely more all round Motorsport proven track record within Australia and are completely Australian. In off road like 800hp+ buggies with monster torque that race here in the NT Finke desert race, there is basically only one manual box used that wins.
Albins
I called them not that long ago to ask a few questions about their sequential, they never mentioned anything about the option for straight cut? But I didn’t ask either, but the standard sequential design is helical cut.
Standard option looks like it, as the pictures in Holinger GTR workshop manual are all showing helical gears on the disassembly except reverse. Main and counter shafts are both splined on gear so they definitely can do it. The earlier GTR boxes the Hollinger GRA-6N and HKS-GTR were only straight cut.
2012 GTR MANUAL.pdf
Same experience as Moray - when I spoke to Holinger couple months ago - helical only.  Not sure why that is now - as I'm sure you could get them in straight cut years ago.
I went with the new Albins ST6-LP - i believe its the only one with a internal oil pump.!
Edited by IMACUL8
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
