Recently I have started getting a very annoying popup in the bottom LH corner of my screen labelled "Popular on SAU" with a preview of a post and post heading - I can't find a way to disable it nd it's giveng me the sh***s. How do I get rid of it?
Spoiler
https://www.sau.com.au/forums/topic/481438-popular-on-sau-popup-how-to-disable/
24 minutes ago, PranK said:
Fwiw this has been in the bottom right corner for many years now. It's not new.
Yeah, but it comes and it goes. Some days I see it, others not. This has been going on for a long time, so it's not related to the recent software update.
I use NoScript to kill most site automations on most sites (and block SuckFace and other trackers) so I'm always willing to credit odd behaviour of this sort of shit to my own hamfisted actions to cripple other stuff. But even if I permit everything to run on SAU I still get uneven behaviour on that stuff. That "popular on SAU" thing annoyed me every time it appeared on the lower RHS also. Mainly because it would hover over something else that I might want to click and I'd have to scroll. Trivial stuff, I know.
No, not trivial at all. If I don't hear from people on issues that affect them then I can't make things better. I'm trying to promote content to encourage clicks but I need to balance that with usability and experience. If I'm reducing people's positive experience by trying to get clicks, then its not worth keeping it.
It's hard to keep making the ends meet these days.
I'm happy to disable or try to show it to guests only.
I actually quite like this feature (mostly).
Sometimes, older topics have come that contain DIYs that I know I will need soon but haven't started searching for yet.
In some cases, it does obscure the very bottom of the screen.
21 hours ago, PranK said:
What about it gives you the shits? Does it get in the way? You using desktop or mobile?
As per GTSBoy, it seems to always be in the way of something I'm reading or want to click on. I'm on a PC, and until a couple of days ago had never seen this popup. I thought it was something new.
  • 4 months later...
The only thing I'll add to this is that lots of these 'Popular' pop up threads are years old.........and then you get somebody that doesn't check the date trying to reply to MrSkyline from 1956.
Dragging up relics from the past.......thats called archaeology!!!!!  So maybe change the 'Popular on SAU' to 'Digging up Dinosaurs '
If it gets clicks that funds the SAU machine I'm happy to deal with it
Without funding what would happen to SAU?
As long as I'm not getting spammed with adds and shiz I say send it
People get spoilt, or forgot about little things, like paying bills
And yes, I'm drinking whiskey at the moment
10 hours ago, niZmO_Man said:
It takes quite a bit of effort to modify the forum software, so the reports and threads are helpful.
What whiskey you drinking mlr?
Was just some cheap Johnny red mixed with Pepsi max
I do overly opinionated when drinking cheap whiskey, well, more so than normal
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
