Hi All
I've done a lot of reading on here about what people are doing for turbo replacements and 99% of the time people have or are looking at upgrades - exhaust etc. and the discussion seems to revolve around that.
I'm a little old-fashioned and my car is stock and prefer to keep it that way so am looking for a turbo to suit. I want a bolt up solution and I noticed a lot of you lads talk about the CGC high-flow. I just rang them and they said that if I were to do that, the car would require a tune and would not run right without. Is this accurate? Am I to understand that the stock ECU cannot be tuned so this is not a solution as I don't really want to stuff around too much.
Has anybody here done this i.e bolted a CGC high-flow to an otherwise stock car? What were the results? Did it run OK as is?
Any advice or help would be much appreciated.
Thanks all
If your car is stock and you want to keep it stock, would you not just get another stock turbo if your current one has failed?
If what your saying is you want an upgraded bolt on turbo that is so small it won't need any supporting mods or a tune, you might find G2 highflow is what you're after. See link below -
https://hypergearturbos.com/product/nissan-rb25det-turbocharger-standard-high-flow-service/
Hi Murray, this looks like the same thing CGC is offering. The issue is because the guts are larger there may be a need for a tune (this is what CGC advised me anyway) which goes to my original question.
From the Hypergear website. G2 is happy with the stock ECU and stock fuel system.
G2 high flow is capable of making up to 230rwkws. It is happy to hold factory boost, recommended for Rb20det engines and Rb25dets working with factory ecu and fuel system.
It's GCG. Not CGC.
You could no doubt get Tao (Hypergear) to rebuild you a stock Hitachi turbo with wheels that are not much different in capacity to the original. He would have to have access to plenty of turbines and compressors that are approximately the same as the stockers. It's just that no-one would want to pay the rebuild cost for a turbo that could have been an actual highflow instead. It will cost the same.
A small highflow will work against the stock ECU. But an important point to remember is that any highflow will flow more gas (and therefore air) at the same boost as stock, so will definitely push your operating point in the ECU's fuel and ignition tables further to the right. In RB25 ECUS, this will lead to more richness and less timing, which is not great. Will use more fuel and make less power than it otherwise could.
An actual proper highflow, a better ECU, some injectors and an AFM are sensible modifications.
You won't be able to run a larger turbo on a stagea with a standard ECU. They are very sensitive to changes in airflow, even a mild boost increase on the standard turbo will throw it off.
If you want to be able to return it to stock, best to plug in an ECU like a PowerFC and put the larger turbo on, reasonably easier to return to stock if you want to.
@RBW49N I want it to be as close to stock so I don't need to change anything else.
@GTSBoy&@DuncanAppreciate the sage technical advice
Thanks everyone for you input. So basically if I want to continue on the keeping the car as stock as possible road, I'm gonna need a either a new or decent second-hand stock turbo.
I guess the next question is what's the best source of either of these?
Ta
There are no new ones. These are ceramic turbine, so all the ones that were going to die from natural causes died years ago and were replaced with the spare stock Nissan had, using it all up. Many have been destroyed since by stupidity (turning the boost up too far).
Essentially, any 2nd hand one you can get that was in good working condition will likely be fine used at stock boost for the rest of time. They've had 20+ years to kill off the weak ones.
Yo get one you'll just need to look at the forums for sales, FB groups (shudder), eBay, Gumtree, etc, for people selling them and try to pick one that is healthy. Import wreckers will also have them and might offer some warranty, which may or may not be useful if you don't install it immediately and discover if it is good or is hiding a problem that wasn't visible on inspection.
Ta
There is a always a few for sale on FB marketplace and they do pop up here from time to time. I have one that needs a rebuild if you want it you can have it just come and get it. Then there would be very little down time
  • Thanks 1
Is there even an ECU that can play nicely with the 4AT in these Stageas? I don't mean like a Motec where in theory you could write all of the code to handle that stuff, actual support where there's a base map that is pretty much spot-on for the transmission, just need to change some calibration values to get things like shift mapping to suit, maybe some timing retard adjustments to get the shifts smoothed out as well.
Yes It can be done with the Haltech elite 2500. Full series 2 auto, fuel and ignition control.
Edited by RBW49N
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
