Hey guys, I'm new round here.
I'm thinking about buying a car in about 3-6 months these are my options from the research I've done. (20-25K budget and I'm on red P's)
1. A non turbo Skyline. From what I've heard it's not a good idea to turbo it later on. But maybe I can reuse the parts if I get a GTT later on and just swap them in. My concern is also resale value, which r34's seem to be holding on.
2. WRX. Non performance. I don't know how good these will be performance wise but they seem the most liveable.
3. The safest and cheapest option I have is an 86 or BRZ. Probs won't turbo, but I can mod it I guess. Only issue is don't think it's a great car long term and resale is kinda trash from what I've seen.
I'm leaning towards the r34, but if anyone has suggestions, would be greatly appreciated!
https://www.sau.com.au/forums/topic/482524-skyline-r34-non-turbo/
I would say forget the Skyline, get the 86. 86/BRZ being the more modern car will be the nicest to drive, so that would probably be my pick. Plus less police attention, decent aftermarket options, etc.
  • Like 2
There's nothing a R34 does better than an 86.
Nothing.
A R34 N/A is not a performance car. It's closer to a Hyundai Tiburon if anything. A R34 Manual GTT in stock form (I.e out of the price range anyhow) is about the same performance in a straight line as an 86 anyway lol.
Also there's plenty reasons why P platers love hot hatches too, as an alternative.
  • Like 2
Yeah, I'll have to agree on the aftermarket on the 86. Thanks for the input!
I've looked at something like a Golf GTI or R as an option, with 4 seats and all. 86 does sound like a better idea though.
I would take a Golf R, faster better, much more comfortable & safer.
Flash, dump pipe, better intercooler, better intake and you'll toast most turbo charged 86 shit boxes.
  • Like 2
Sounds like a plan. The R does look quite nice and 4 doors...
Does the turbo go stututu though
Intake pipe, pod filter, pod enclosure and either delete the BOV (DV as they call it in their realm) OR just get one that's adjustable and clamp it down tight for that doseeeeeeeeee life.
  • Thanks 1
Golf R great choice as well, impress your mates and ya mum at the same time!
Seriously though, those little VW's are pretty quick. Between the 86 and the Golf, you've literally just described almost half the regular field in our local time attack series haha. None of them are anywhere close to winning, but they're giving it a red hot crack 😅
  • Like 1
  • Haha 1
I always think Lancer Ralliarts are the biggest unknown sleeper. Same drivetrain as the Evo X, with slightly slimmer bodykit. Same potential.
Look pretty shit though.
That said, also cheap. Unsure if P platers can drive them but if they can, then oh boy there's potential there too.
  • Like 2
Yeah Golf R is probably on the table if I get one for a good price. As long as they sound good I'm not too fussed about speed especially on the P's.
I was looking at one this morning! Price range is definitely a big pro but yeah, they look worse than my 2006 corolla hatch hehe
  • Like 1
However, they are legal (as are the sedans) and the Evo X platform is going to run rings around any hot hatch, especially if you go modding. The sedans just look like a lancer instead of a WTF is that hatch going on.
Yes yes, mods are also not really legal but there's plenty of uh, invisible mods that go on that evo motor.
The sedans don't look so bad....might get some cop attention but it seems like a good choice too...thanks for adding another option now I'm confused aha
Here's an idea, buy a R33 GTS-t OR R34 GT-t, de-rego it and just store it.
Buy a P plater fun, stock car, enjoy it. Then once you're ready, sell and play with the whooshy break oil pump Skyline.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
