After much whining over the years over the quality/readability of the wiring diagrams in the age old pdf scan of the R32 GTR workshop manual, I pulled my copy out and ran it over the scanner.
Now, it's not perfect. My paper sheets are assembled from photocopies of the originals that I had to tape together. So there are slight discontinuities here and there. On top of that, I had to scan my long taped together sheets as A4 segments and reassemble them on screen, which involved rotating some parts by little angles like 0.15°. But they are pretty good. On top of that, I have left jpgs of the raw individual scanned parts for each numbered assembled scan so you can see the points where they join without any little artefacts caused by my manual stitching.R32 GTR Wiring Diags.zip
The quality of the scan is much better than the old pdf, but there is only so much detail that can be pulled out of the original photocopy. Most of the wiring numbers and colours that were hard to read before are a better, but some remain fairly hard to see. I tried 600dpi scans and it didn't help at all. This is about as good as it gets unless someone scans an original.
*update Jan 2024*
Thanks to GTSBoy for the previous photocopy scans and suggestion on how to obtain higher quality scans. I actually have the original printed manual and have finally scanned the wiring pages from it.
R32-wiring-hi-res.zip
The quality is better than was available from the photocopies and pretty much everything is readable if you zoom in far enough; it is only some of the physical wiring pin references that are a little hard to read (which is true in the printed original too).
Edited by Duncan
Update with higher quality scans
  • Like 2
  • Thanks 7
Thanks on behalf over everyone who will use these but never consider that someone put in the time to do them :) These copies are definitely much better than the ones in the pdf
I do actually have the original originals that I could scan too, but as you described I don't really know the best way to deal with the very wide fold out pages.  If anyone has suggestions on a way to get a better outcome let me know and I can give it a go.
  • Like 1
Wow that makes a huge difference. The wire labelling is so much clearer, makes everything easier to follow.
I'll be printing these out to replace my dogeared prints of the old pdf/scan.
Thanks for sharing.
Edited by alexj
The time is worth it to simplify future efforts to help peeps on here.
You just have to scan them on any A4 (or better, A3) flatbed in pieces with enough overlap to allow reassembly and keeping them dead straight. Gray scale 300dpi will do. Then assemble in a graphics program like the Gimp. I tried using stitching software but it can't cope - it's designed for photo panoramas.
If you want to put the time into scanning the original, you could upload them to OneDrive/Google/whatever and I'll stitch them.
  • 3 weeks later...
  • Duncan pinned this topic
  • 11 months later...
OK, so if you haven't seen in the first post, per GTSBoy's suggestion I have done high res scans form the original printed manual (instead of the photocopy which is not the same quality)
Zip file of the all diagrams (excludes Oz specific, they are in the first post if you need them)
C-1 Logical Wiring diagram (better for understanding)
W-1 Physical Wiring diagram (if you are trying to physically trace something)
RB26DETT Physical wiring diagram
W-3 ATTESSA physical wiring
W-4 Door physical wiring
W-5 HICAS physical wiring
W-6 Air con physical wiring
  • Like 4
  • Thanks 1
It was very high tech :) Officeworks A3 scanner at 300dpi black and white, then stitch each A3 scan together manually in paint. It has worked pretty OK, you can see the folds in some early scans but I back folded the later ones and they were OK
  • Thanks 1
Absolute Legend 🍻
After fighting with the scanned ones for the last 10 years this is a God send
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
