On 6/12/21 at 2:23 PM, Nicko69 said:
Hi all got a R33 pushing 450rwkw manual box got a triple plate clutch in it. I'm after any info on a clutch that will take the power no worries but is easier on the drive for street use??
Xtreme 230mm organic twin plate
I was running the direct clutch services 1000hp rated twin plate clutch, I thought it was really nice, good pedal feel, not too heavy, a little ‘bitey’ on initial grab, but nothing excessive, got used to it pretty quickly, it held just over 500kw for over a year, when the car was pulled apart had it checked, was told plate wear indicated it had done what they considered’ bed in stage. Lol
it will be going back in the car when it all goes back together.
  • Like 1
I might try out the Direct Clutch twin plate, they run a mixed setup.
  • 1x plate is organic
  • 1x plate is ceramic
Which in theory makes it driveable, from what I hear it seems to be quite nice to drive from a handful of people. I've yet to experience this myself.
Hopefully this helps.. I have a OS Giken R3C, triple plate, and I find that I need to be on my toes in terms of shift quality. I find its very sensitive. When the clutch is cool/cold its easier to drive/ride it, but once its warmed up, there's hardly any give. Bite point is towards the top of the pedal, but not quite. Street driving isn't very friendly.. I have to give it a bit of revs to take off - A little too much and she chips, too little(sometimes all 4), and I'll stall(Whilst everyone thinks I cant drive a manual).
Put it into perspective, my mate with a nismo twin plate(comp edition) hates my clutch.
Its a bit of a pig to drive imo, but I'm not fussed, cos when I do launch it, it grabs hard.
  • 3 weeks later...
I’m switching from a nismo comp spec to 9 inch dcs sintered twin plate shortly. Planning on going 26/30 later in the new year pushing well over 500kw. The nismo has been great. Is holding 360kw at all 4 well and has been in for the last 4 years on the same power. The nismo is perfect for the street in a standard car as it feels like stock. Only down fall is the nismo is crap for drag racing. I’ve done about 25 passes on sticky tyres and it’s starting to get really worn out and very high take up point. Last drag meet I did, slipped it a bit too hard getting used to the new surface at the creek and it got too hot and couldn’t change gears until it cooled down, and also cost me a starter motor as it locked up from all the material. Plus the novelty of a lightweight flywheel is wearing off too
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
