On 12/12/21 at 10:34 PM, Robzilla32 said:
Remove the sound deadener with dry ice; wire wheel the rust marks; paint with kbs; reinstate the seam sealer; cover with new sound deadener
How many hours or labour and material would you estimate for this to take/cost?
Well tbf he's asking someone who has had it done so he has a rough idea of what it's cost others to establish a ballpark.
Sure, it cost $XYZ 3 years ago isn't perfect data, but it's something to know before he talks to a paint/body shop and they hurt him in the wallet
  • Like 1
  • Thanks 1
Someone just told me that factory R33 GT-R didn’t have sound deadening in the boot. Is this true?
I’m considering removing the sound deadener with dry ice myself, and then paying someone to remove rust marks, paint with anti rust paint and reinstate the seam sealer. If I don’t need to reinstate sound deadening hopefully I can keep the cost down.
Edited by sonic99
So, I am a DIY type. Disclaimer: I am an amateur (very).
Costs, time and risk may not be relevant to others. All of the work that I described above was performed by me and I am performing this work throughout the whole car so difficult to say how much for the boot only.
If you want to do the sound deadener only in the spare wheel well, then not much point TBH. $20 and an hour of your time; if that. It is the heat cycles; seam sealer overrun; and carpet that makes this job a PIA when you move into the rest of the car.
20201228_141423.thumb.jpg.f981ca83240878c4b439f3f3bba1bf33.jpg20210306_144108.thumb.jpg.3a15b34d12f88fb3d8b560f8078df68f.jpg
  • Like 1
  • 3 weeks later...
On 1/1/22 at 1:52 PM, Robzilla32 said:
Probably just 1kg. From memory that was the minimum that BOC would sell.
Thank you!!! I ended up getting 2 kg but they filled up a 5kg bucket. I got most of it off but there is still some left. What remains is kind of sticky. Not sure why I was unable to get it off. Where to from now? How do I remove the rest of it?
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
