Hey I've got a s2 c34 with rb25det neo after I installed a highflowed 25det turbo the car hesitates for a second between gears when coming off boost then back on throttle. I was running a frontmount no problems with the stock turbo and I've jst installed the sidemount and now it's fine again with the frontmount and highflowed turbo is the afm not coping with the extra air flow or what I'm stummped
Edited by Jarrod rb25det
https://www.sau.com.au/forums/topic/483484-c34-25det-neo/
Any larger turbo worth using will flow more at at "low boost" than the stock turbo does wound all the way up to "turbine flies off". You can't really go past the airflow available from the stock turbo at 10 psi without the stock ECU starting to get upset, and at 11-12 psi it will really be pissed off. I wouldn't contemplate a highflow on a stock ECU without Nistuning it to get around all that.
  • Like 1
https://www.sau.com.au/forums/topic/483484-c34-25det-neo/#findComment-7962435
On 24/03/2022 at 12:24 PM, Jarrod rb25det said:
Like I said I have a link g4x but havnt been able to tune it that's not my question anyway I'm jst cruising until it gets tuned but with the frontmount it buzzes out and the sidemount it doesn't that's my question
I think you've just demonstrated how shit your side mount intercooler actually is in pressure drop and flow across its core compared to your front mount.
  • Like 2
https://www.sau.com.au/forums/topic/483484-c34-25det-neo/#findComment-7962446
go back to the front mount, install the Link and road tune the low load stuff, plenty of people can help like myself or @Dose Pipe Sutututu
Depends where you live an experienced member may be able to help with the install & setup
  • Like 2
https://www.sau.com.au/forums/topic/483484-c34-25det-neo/#findComment-7962453
On 3/25/2022 at 4:54 PM, Jarrod rb25det said:
I've now installed the link g4x calibrated everything set base timing and finally got it running afrs are rich on idle but fine cruising but ran out of daylight so will have to tidy things up tomorrow
Good work
Easy to trim fuel, build a Lambda/afr target map and can use the quick tune function to get it pretty good quickly but need to turn off any other trim tables.
  • Like 1
https://www.sau.com.au/forums/topic/483484-c34-25det-neo/#findComment-7962515
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
