Hi guys just wanting a little info
i have a bnr34 with a forged engine i built years ago bottom end finished havnt touched the head yet. Wanting to push around 680whp on 100octane and close to 800whp on e85 in New Zealand.
mods so far
billet gears in oil pump
cp forged pistons
manley forged h beam rods
custom sump 9L
oil returns drilled will also run a head drain
oil restrictor
plazmaman 100mm intercooler on the way
looking into a pt6466 gen 2 not sure what a/r to run looking on the t51rmod website as i want to do the t51r mod also thoughts on this turbo? Most likely divided also
or is a 6466 over kill drop to a 6266?
i will be getting head ported may even have cnc porting. Unsure on cams duration and lift etc?
looking at maybe a sinco top mount manifold unsure on gate size also?
have thought about fueling yet
this will be a street car with a few track events
https://www.sau.com.au/forums/topic/483844-forged-rb26-project-please-help/
If I were you and were sticking with stock displacement, while wanting it to be nice and responsive while also being able to do near 500kw on pump, and 600kw area on E85 then I'd go a Sinco T4 divided manifold, 1.05a/r EFR8474 and if you're doing headwork then go the Kelford 182B (260deg, 10mm lift) cams - make sure the headwork suits high lift cams, including clearancing.
My assumptions here are that  you're likely to be tuned on a Dynapack (virtually everyone here use hub dynos) and RBs and EFR8474s are a match made in heaven.  500kw on pump is a bit of a stretch, and the slightly shorter duration cams I've suggested won't make that any easier - but in all honesty that setup will still work very well... whichever fuel you run you'll also have the option of ramping the boost up in the higher rpm when natural torque drops off if you want it to carry power a bit better at the higher end.
I know someone with 520kw @ hubs with an EFR8474 on BP98 and various people who have gone over 600kw @ hubs also with 1.05a/r EFR8474s, and they drive insanely well - basically significantly more responsive under foot than a 6266, while making more power.
In terms of wastegate that comes down to what the minimum boost you need to run is, twin 40mm obviously is proven if you go separate wastegates - otherwise something in the 50mm area is probably a good idea.   The smaller the gate, the harder it is going to be to hold a lower boost level.
  • Like 1
On 12/7/2022 at 12:01 PM, Dan BNR said:
Seen a few people pushing some good numbers with the 6466 just dont want heaps of lag. Not sure which a/r to run
Those numbers are at the hubs, I’ve seen a few able to do 600kw at the hubs but none at the wheels.
I’ve got a 6466 myself and on my 2.6 it was an awesome turbo. I am currently building a 2.8 and it will be going back on with a bigger rear on it and will see how it goes on that. On a 2.6 chasing the number you are I’d put a 1.0 divided rear on it
My 32 with the 6466
On 26/08/2021 at 9:55 PM, BK said:
R32 GTR
Nitto 2.8 stroker
Precision 6466 T4 divided 1.0 a/r
Haltech Elite 2500
BP ultimate 98 RON unleaded
456kw / 611hp at 22psi
A bit more on United E85 at 32psi
Full specs on build thread
On the other 32 we've gone the 6266 T4 with 0.84 a/r
Just a suggestion i would 800 whp with h beam rods are taking them to about there maximum A beam rods are much stronger and rated to 1000whp which would give you a better safety margin.
Bare with me guys first time iv used a forum haha. Im definitely wanting to stick with a single not twins.
Is this what you guys would recommend for a big single? T4 divided 1.06ar vband out. And of course the t51r mod 🤷‍♂️😂. Ill look into those 260 cams.
never heard of A beam rods??? Thought H beam were the strongest?
Why the T51 mod ?
Anyway I beams all the way in both of our 32s, but arguably just or more important is the fasteners.
The 2.8 has ARP2000 3/8" rod bolts and 2.6 runs the highly recommended 7/16" bolts in ARP2000 which weren't a thing when we did the 2.8 on a 26 conrod (only RB30 at the time). Nitto and Spool now do 7/16" RB26 121.5mm capable conrods, so price not a concern -
ARP CA625+ 7/16" is the shit 👌
Pretty sure the T51R mod affects the compressor map and probably not in a positive way.
Don't think anyone has (or anyone in their right mind would) suggest going twins for this kind of situation.
The exhaust housing will very much depend on what turbo it is, not all 1.06 exhaust housings are equal - there can be a HUGE range of what they will support depending on the wheel sitting in the housing and the cross section of the volute.   In regards to the turbos being mentioned here the 1.00a/r hotside would probably be ideal for the 6466, or the 1.05 for the 8474.
Btw here is a dyno plot for a 1.05a/r EFR8474 on an RB26 with big cams and a ported head on BP98, 14psi and 21psi boost levels shown.
As far as im aware the t51r mod doesn’t affect any performance, wanting to do this just for the sound. I had a brand new t51r spl that i got in a deal but i knew it was going to be a huge lag monster so iv sold that and now would like to try this t51 mod out.
i see a few of you guys talking about rods etc. my block is complete and finished so ill be running the H beams.
figures i want i was supposed to say at hubs not wheels just as a round about figure.
Would you guys recommend the pt6466?
the 8474 in my eyes is a ugly looking turbo 🤦‍♂️😂 you may laugh at this but im pretty keen on a nice clean engine bay so id prefer to stick with something that looks kinda cool too haha but if its really worth it then ill sacrifice it.
pretty new to all this so i dont fully understand alot of this turbo flow rates etc and kind of teaching myself as i go.
another reason i was more leaning towards a 6466 rather than a 6266 is i may look at a rb30 or 2.8 if the late future not 100% sure thoughts?
keep it basic Appreciate it guys
Edited by Dan BNR
Didn't read my post above ? I run one and posted the results for you, so that would be a yes I recommend - will not disappoint.
Never considered Precision turbos especially aesthetic lol.  The EFRs are definitely an eye sore as default but imho if you don't use the BCS, BOV (using a blank plate), internal gate and powder coat the compressor housing or something like that then they actually are one of the better looking housings but that's all additional cost on top of an already spendy turbo.
It is definitely a better unit for your needs otherwise but yeah, should have lead with the fact you are happy to compromise some performance for personal aesthetic tastes - the short answer is that until a few years ago the 6466 was the absolute best option for what you want from it now, and it's still up there... So absolutely worth it if there are other factors which make it appealing to you.   No one is going to see it as a silly choice!
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
