Also, i think that the finned RB cam covers I purchased are not the genuine rb20 red top finned ones. I believe they are standard 20 covers that have been milled very slightly to create the raised fins… Im not sure if the guy I bought them off even knew, however, the fact they didn’t come with a matching valley cover is now a bit of a give away..
Anyway, annoying as it is, they are still a unique piece and they were modified very well, so I will get them painted up and put on the car. Now to chose the paint color…
  • Like 1
  • 1 month later...
I have been stuck into house renos every spare minute I’ve had lately, so the skyline has been neglected in the garage..
I have decided not to run the finned cam covers and sold them, I just wasn’t 100% happy with them. I also got scammed on FB market place, where I thought I had purchased a nice condition boot interior. So fair to say enthusiasm to work on the car has been low anyway..
it’s raining today and the kids are out of the house, so I thought I’d find some motivation and finish up the A/C install:
I gave the bonnet latch and bracket a paint black, as it was pretty ugly and so it’s less visible through the grill. The compressor is so much smaller and lighter than the old OEM unit. I also had to modify one of the AC hard lines, as it was fouling on the wastegate down-pipe. This isn’t a criticism of the FPG kit, as there is no way he could allow for every turbo/wastegate/exhaust combo out there.  I actually think it sits nicer this way now anyway, as the lines sit nice and parallel against the wheel arch.
I think the favourite purchase is the purchase of the bonnet prop/stay clip, as my car has never had one in my ownership..
  • Like 3
AC is now all wired up. The fan switch and pressure switch are hooked up as inputs via the ECU and the compressor is an 8A HCO via the PDM. I’m assuming I need to set the pressure and fan switches as generic switches/inputs? And then have some conditions to switch the fan and compressor on/off?
engine bay all buttoned back up:
I ordered a TAARKS power steering pump AN10 fitting, as I’m thinking I’ll mount the power steering reservoir in the airbox, to tidy up the bay a bit more.
i have also noticed some brake fluid leaking around the reservoir of the BMC, so hopefully nothing serious. I’ll be flushing all the fluid and replacing when I do the rotors and pads.
in other news, I have booked a conference in Sapporo Japan at the end of August, so I have given myself three full days in Tokyo, so feel free to provide recommendations on where to go. The Nismo factory/showroom is top of the list so far.
The pressure switch should be inline with the + (I assume, or possibly the -) to the compressor. PDM can supply it power at all times when AC switch is on and throttle is less than say 80%, the pressure switch will just cut the circuit any time its threshold is reached.
At this stage I have wired so the pressure switch and fan switch are separate switched inputs in the ECU. I have then provided an 8A output direct to the compressor for switching.  However, I do like your way, as it would mean one less input needed.. maybe if I run out I’ll switch it.
are there any other conditions you would turn compressor off? Launch control active etc?
  • 3 months later...
On 19/05/2023 at 1:39 PM, R3N3 said:
Here are the final dyno reports for each boost setting:
wastegate spring (7psi):
ReneNielsenFAD745Wastegatespringpressure.thumb.jpg.42bcd5fe29581981ae4a9ed83f0f144e.jpg
note that gate pressure sees the boost creep up to 12psi.
12 psi:
15psi:
20psi:
Went for a quick drive up and down the street after the tow truck dropped the car off and man it is nice. The sound of the turbo, exhaust, intake and BOV is just so nice! The power feels so linear in how its delivered.
The turbo, is the rear housing .82?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
