Hi all to the community, I am new in the JDM scene and i am so exited!
i would like some advice from all and possibly what i can do, will try to add as much as detail in for everyone !
I have recently purchased a r32 gts4 skyline with a rb26 in it. so the previous owner had it for 6 years and always serviced ect it every 5000kms, the engine now has 180 xxx kms on it. back to the question, he had issues with the twins so he removed them and bought a single turbo garret ec-1 a/r7 - xjm 62406 and a manifold and wastegate to suit. he then lost interest and the car sat for 6 months. i have purchased the car like this and went to 2 tuning shops these are my options
1) tune shop 1- chuck n5s 2860s turbos, aftermarket manifold, dump pipe + tune
2) tune shop 2-   bring the car in (with the twins again) and they will have a look at it because it might be the load limit and the turbos might be fine. they also said i might have to look into a rebuild as its at 180 000kms.
3) ????
thanks everyone for reading this! i hope all is having a lovely day / night
Ok. So along with the car you were given the complete stock twin setup and also an aftermarket manifold, turbo and gate?
Are you 100% sure it is an "EC-1" turbo? I've never heard of such a creature before.
wanting to get a workshop to do the work but done know what options to go with or whats the best thing. just got in contacted with the owner his got the twins and all the bolts for me if i wanted
@Murray_Calavera
Yeah ok, the most important thing then will be to find a workshop you can trust. I'm on the other side of Australia so can't make any recommendations unfortunately.
As for what you have that workshop carry out, you've got a lot of options. I'll throw in my 2c
Option 1 which is the cheap option. This only applies if the previous owner can supply 100% of the parts for the twin setup. Have the turbos rebuilt/high flowed by HyperGear and go back to the twin setup.
Option 2. Previous owner can't supply the twin setup? Hit up some wreckers and buy a complete working twin setup.
Option 3. Bin all of the single turbo parts you've been given (from what I can see, it all looks like rubbish. It's very expensive paying a workshop to try and make rubbish work, then you have to bin it all and start again anyway thus paying twice). So, this option is to start again and buy a quality single turbo setup. This will get expensive very quickly, you could easily spend $4,000 on just the turbo and manifold...
All comes down to what you want to do with the car long term really.
Got it mate thanks heaps, the old turbos are GT2859R-9s and the cars got a oem fuel pump, 880cc injectors and apexi fc comanders and on the dyno it hit 370hp
i was hopping to hit around 400ish. is that possible with the twins?
and also yes hes got all the bolts and parts for the twin turbo set up only thing it will need is an oil line because he cut it
@Murray_Calavera
Hard to say what your next setup will make without knowing what you'll be running.
Have a look at the RB26 turbo upgrade dyno results thread for ideas about what parts you'll need to hit your goals.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
