I just did a intake plenum job and replaced all the coolant lines. Now i am noticing that coolant is collecting on top of the intake manifold by the balance tube. I am puzzled by where this coolant could come from?? Does anyone know?
It was hard to get good pictures of it but it looks as if it's coming from the balance tube.
The red arrow is where its collecting
Edited by kevboost7
Pretty sure that coolant has come from the head coolant breather on the top right in your last pic, you can see the witness trail from it.
But, there is coolant in the intake manifold after the throttles, so depending what you changed it could also be one of those gaskets.
That last picture wasn't mine. I found it on google.
When you are referring to the intake manifold, are you referring to the balance tube right on top of it?
22 minutes ago, Duncan said:
Yes, the screw in the middle is the coolant bleed screw for the manifold, as it is higher than the radiator cap
wait, its not that... because that picture i posted wasn't a picture of it, i just found it on google. Is it possible the o-rings on the balance tube gone to crap?
The balance tube has coolant flowing through it. There are a bunch of o-rings that seal up the balance tube to the intake manifold. That can be one leak path. The other is the intake manifold up against the cylinder head. The throttles themselves don't get coolant flow to my knowledge but the intake manifold does. I recommend undoing the harness on the balance tube so you can get a better look at where the leak is coming from. Certainly a lot easier than getting eyes on the back of the intake manifold up against the firewall.
1 hour ago, GTSBoy said:
USB/WIFI inspection camera is only $30 on eBay. Just sayin'.
Those things are so low res as to be useless for spotting leaks unless it's super obvious. It really shouldn't be that hard to figure out the source of the leak. If the actual photo wasn't out of focus it would be pretty easy to see what's going on.
Not true. I'm not talking about those shitty all-in-one borescope things. I'm talking the ones that connect to an app on your phone. Quite good resolution. I use one regularly for inspecting the insides of industrial equipment. They are cheap, cheerful and I wouldn't be without one.
  • Like 2
Did you buy yours on ebay? Would you be able to link to the listing? Or at least the brand name they use for it. Thanks!
I had a quick look at finding just a non-shit camera at some point but going through the listings I found it hard to figure out whether I was looking at junk or something that's actually worth buying.
Would love to get a link, I keep using a chinesium harbor freight one and the image is horrifyingly blurry. It was useful for getting that paper towel out of my intake manifold but anything smaller than that and I had a hard time spotting anything.
Yes, eBay. Have had for a few years now, so the listings are not the same. I would suggest that most of these would be sufficiently close to the same thing that it wouldn't really matter.
https://www.ebay.com.au/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=wifi+inspection+camera&_sacat=0
This one though, appears to be the same one I bought. I got one with a 2m cable, for compactness, because I carry it all around the world, but you can also get 1, 5 & 10m lengths. The longer lengths are not useful without taping it onto a stick if you need rigidity, and not steerable if you need to control it inside something, but still might be desireable for some. But 2m seems like the best option to me. I only paid ~$25 for the 2m back then. Looks like prices have, understandably, crept up since. I did "guess" quite well at $30 in my first post above though!
https://www.ebay.com.au/itm/363941200352?hash=item54bc9601e0:g:zqAAAOSwDUpi5TcL&amdata=enc%3AAQAHAAAAsInvOgSeC%2FpzavmgsvfJjNJTNrIf1ZyW7EYIwG76Nfg3x4%2BKp1rYUt%2B3pIBPmvkZjm4OmBvjomQngDzTt1odFGXBk5JMHPSKgfEbZnU7vgu19BjYqHS9PlctnhLwkn3XyePoBjvVT5I2BoAuocIUB7isNXWIhTuW2161XJ5uO%2Bz6KujjZUBq%2Bh4%2B2G7DOke3o13w56ZqkZFPpF071P0p6sGQbfRo4ghPHK06Lf7Sw2Zo|tkp%3ABk9SR4y0qOj9YA
  • Like 2
  • Thanks 1
Thanks @GTSBoy, much appreciated! Just put in an order for the one you mentioned. To me they all look the same. It can't be any worse than trying to point the phone camera at things.
Should be here within a week or so. Can report back then on what it's like @joshuaho96.
Let says that the o-rings went bad on the balance tube, would i be able to replace those without having to remove the intake plenum?
Dear god i hope i dont have to do that job again. I just did it a week ago...
Yeah not fun...but back to an earlier question, exactly what did you have apart. It is highly unlikely something you didn't touch started leaking straight after you did something.
Did you just remove plenum, then throttles as a single unit, then intake manifold as a single unit? Or did you partially disassemble one or more of them?
I should add, a radiator pressure test kit might be worthwhile if you are having trouble finding the leak. It pressurises the system from the radiator cap and  will make a leak location obvious
You can try but I have a feeling the answer is maybe not. The hoses and pipes that hold it to the vacuum box under the plenum are a really tight fit.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
