24 minutes ago, r32-25t said:
There’s still a lot of work to go into that job, it won’t look anything like that when it’s finished
But it shouldn't look like that now
Precedence should have seen the pole moved before the road was laid down when they decided to realign the road, it should have been moved before working the subgrade at the lesst, not after a base has gone down
Problems will occur after the pole is moved
I've built plenty of sealed and unsealed roads with my job, that there is poor engineering practices, there is no way that would cut the mustard where I work
I've seen plenty of roads that have needed upgraded drainage where they have dug trenches across existing roads to install culverts, within a few years, or something even months, the excavations will eventually consolidate causing low spots in the road surface, especially if they only use a whacker packer for compaction
That pole probably goes down 2 meters, that's a big excavation to remove it, or, like I've seen local councils do, dig down 500mm and cut the pole off, which works until the stump eventually rots and the ground above subsidies, leaving a depression which will eventually fail
We do alot of quality assurance IRT compaction density for our civil construction tasks, hell, one of my jobs is instructing on a course that deals alot with quality assurance, from Geo-technical site investigations for planning, using moisture mensity gauges or old school sand replacement tests, as well as best practice for all of our plant operators
Looking at that pic makes my head hurt
Subsidence under a road is a bitch.
Just look on rural highways, and along the shoulder randomly therell be subsidence holes, just small bumps. That's just from a core sample being taking as part of the construction, and that's what, a 3inch diameter hole at maximum?
But for removal of said post Mark, I'd recommend one of the big drill augers to drill a big ass hole straight down through it, and keep performing slow but continued filling and compaction. At least then it's not a huge hole having been dug, just one the diameter of a touch bigger than the post.
On 19/06/2023 at 6:23 PM, Duncan said:
I just wanted to share this effort from Goulburn Mulwaree council
Full marks for resealing the road. Not so much for attention to detail.
ah nice, to re-fill the holes left from moving the poles will cost you +50% council fees from next quarter onwards.
On 4/4/2023 at 6:19 PM, Duncan said:
Ha! That thread has been up since you last logged on.
I have a bunch of other stuff to move, wait until the internet finds out I have a working Epson EJ1 I don't need.
So, I saw you uploaded a video to YouTube demo'ing the Epson EJ-1, I'm curious about it, what communication protocol does it use to the car to get the data for the display?
I feel that you need to get that display up and running in the GTR :P
Yeah I'm selling that shortly (once I get it boxed for postage). I've had it in the stagea for about 15 years but since I recently moved to Android/Realdash form the Link via CAN it is not needed any more
I think it is pretty impressive considering mid 90s electronics. It taps into ecu wires for RPM, speed, injector duty etc then displays values based on DIP switches. I had it set up for RB but it covers about 20 models from the era.
A small can receiver with an Arduino, and a few lines of code and we could have hooked it up to the Link instead :P
  • 5 weeks later...
10 minutes ago, r32-25t said:
Was great, we are going back at the beginning of may.
what have you been doing lately?
Wow! Loved it then. It’s my all time favourite destination. I think it gets cooler every time you go.
Not much news my end! Same old! Biggest thing is that I’m trying to get a business off the ground. It’s a tad stressful but it’s now or never!
What about you? It’s been agessss!
Definitely loved it, we spent a week in Tokyo this time and still think we could spend another 2 week there just seeing thing we missed.
business sounds fun, what type of industry is it in?
I’ve basically just been working and building that same stupid car that every time I get close to finishing it I change something and send myself 10 steps backwards lol. Have you still got the dr30?
Business is a retail advisory business specifically property. So helping retailers come up with a network strategy and then deliver, ie negotiate on their behalf to acquire the right locations at the right cost. I used to do this working for the actual retailer, but now I’m out on my own.
Lol re car build! Thing is, when you finish a build you need to start again anyway…so I think it’s better to change the goal as you go…happy for you to steal my excuse
yeah I got the dr still, I’m trying to sell it now. I’ve advertised it for $35k
I’m going to have to because I ripped it heap of stuff of the other day and am talking to a fabricator to change a bunch of things
I thought in todays market your car would fetch more then that, if not it would Al pay be worth sending it back to Japan and selling it to a collector over there
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
