Hello just wondering if anyone else has had any experience with ks racing manifolds, I recently purchased a top mount and am happy with the overall quality but the angle of the t3 seems to be pointing the turbo  really close to the valve cover, I currently don’t have a turbo to test fit but am looking to get a 3076 and am thinking I may have fitment issues and was wondering what people have done to counter act this, and yes I’m aware 6boost is what I should have bought before everyone comments that haha. Any input appreciated 🥂
26 minutes ago, GTSBoy said:
Does seem to be a stupid angle. You might end up needing an angled spacer. The trouble with spacers is they use up....space and the angle might get better but the room left is still not enough.
Yea I was thinking about a spacer but came to the same conclusion I was hoping my eyes were playing a trick on me and someone has had success with the same manifold
Sorry but WTF is that merge collector 😳😳😳
I sincerely hope that u got that for free or basically free.
I can’t see that working out for you. The most hassle free way to fix it is to take it off and buy something better.
  • Like 1
yeah sorry but that does look pretty sh1t. I use one like this https://www.aliexpress.com/item/1005003648296789.html?spm=a2g0o.productlist.main.11.6567474c9ga2rG&algo_pvid=912783c9-3044-4f88-a035-728286787b0c&algo_exp_id=912783c9-3044-4f88-a035-728286787b0c-5&pdp_npi=4%40dis!AUD!192.70!192.7!!!121.98!!%402101f49f16923538504684434e3acc!12000026642021204!sea!AU!4138068839!&curPageLogUid=W4PW53XF41pW
yes the wastegate outlet is shocking. No argument there...but with an EBC and the right sized turbo, boost control is not an issue. I was prepared to internally ground shite welds etc but it didn't have any issues like that, it is of decent thick construction, 3?+ years and no cracking, apart from where the wastegate tube comes out of the manifold. Welded that up and welded in a small brace to that tube, and haven't had any further issues. Fits GTX3076 just fine. I was looking at 6boost but bought this cos it was about $280 aus delivered so why not, and very happy with that choice years on now.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
