Hi just looking for some advice, I wanted to replace the clilpack wiring loom in my 93 GTST , but have found rather than having the standard 7 pin plug, ive found it has a 6 pin, the only replacement I can find is one that suits the 33 GTR, but mine has an earth wire and the GTR does not, but also keeping in mind this car is in a mess and the ignition control module is not even fixed to the car, ( got it this way and plan to sort it all out )
Any advice would be helpful, I'm not sure what to do TIA
https://www.sau.com.au/forums/topic/485339-r33-gtst-need-advice/
1 hour ago, Murray_Calavera said:
15 minutes ago, Dose Pipe Sutututu said:
Delete the ignitor crap, then go R35 / 370Z coils and a new loom.
Which, straight up, is this
https://www.wiringspecialties.com/r33-gts-vr38-coil-pack-conversion-harness/
or this
https://www.wiringspecialties.com/prp-r35-gt-r-smart-coil-kit-for-rb25det-s1-s2-bracket-hw-stalks/
But you cam also buy equivalent stuff direct from PRP or Goleby's and all the other usual local suspects, without the USD and shipping costs of wiring specialties.
Edited by GTSBoy
2 hours ago, R33tur said:
I'm just confused as to why they used the gtr loom rather than the standard
Because there's no special difference between the GTR and 25 looms (that matter, anyway).
The differences that matter are that R32 and S1 R33s had dumb coils, the S2 R33s had coils with built in igniters and then so did the R34 stuff (but with other differences, like physical mounting differences). So if you're replacing the coils with R35 coils anyway, then all you need to do is match the plugs.
On 15/03/2024 at 9:33 AM, GTSBoy said:
If you have to change the loom now, you might as well not waste the money put into that, and go the whole hog and upgrade the entire system. The poor (or tight-arse) man pays twice.
I don't really agree....the stock ignition system is fine for most use as long as the loom and coils are in good condition.....changing to different coil setups not necessary unless you are looking for big power.....and I get the impression OP has a lot of unwanted money to spend getting the car running properly
  • Thanks 1
Thanks mate, my first intentions were to make changes, upgrades and all that's kind of stuff but that was Before the car had arrived, now I'm looking at just sorting out basic thing's you wouldn't expect to have been worried about with a car that was described as only having a knock in the rear suspension, the list has gotten bigger as we started to work on it. I wouldn't wish such a car on my worst enemy. But it is what it is, and I have to make do with what I've been given, just hoping to make it into something half decent.
  • Like 1
Spends money on loom, then finds out OEM ignitor is cactus, spends money on that, then finds OEM coils are cooked.
Then goes, ok, time to upgrade to a R35/370Z coil setup.
Now left with a barely used new loom, and a barely used new ignitor.
Can't sell the latter two for anything to recoup costs.
TLDR, just get a R35/370Z coil kit.
Do I need anything else to do this conversion? 🤔
6 minutes ago, Murray_Calavera said:
What ECU are you using?
Standard from what I can tell, the car was shipped to me and I've found it all to be in a big mess, we've come to find alot missing and stuff mixed up, looks to have been an ex track car, maybe set up for drifting. We think a bigger turbo and front mount intercooler previously, turning in to a massive headache.
I was hoping you were going to say you have an aftermarket ECU.
So, personally I wouldn't buy a R35 coil kit without already having an aftermarket ECU. I would be concerned about dwell time settings that the R35 coils want, might not match up with the original coils dwell time. With the aftermarket ECU you can set the dwell times so happy days. Stock ECU... not so much.
I don't know how many people out there would be running $1000 worth of coil kit on a stock ECU, so dunno if anyone can personally confirm that it runs well on the stock ECU?
The dwell times for R35 coils are a decent match with stock RB ECUs.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
