Hi guys,
Looking for some help from the brains trust again please.
Recently the RB20 in my 32 overheated, I was able to limp it home and discovered absolutely no coolant in my radiator and steam pissing out of the overflow.
Since then, I have flushed the block and the radiator. We discovered that the heater box was blocked so until I can replace that we have deleted it by removing the hoses from the firewall and connecting them to each other. Filled up with coolant and demineralised water and have bled it on a number of occasions for 30-60 minutes.
Now I can still drive the car but after about 30 minutes the temp guage starts shooting up and I'm at a bit of a loss as to why.
The thermostat appears to be working as the lower rad hose does warm up with the rest of the engine. I'm not losing/leaking any coolant. No oil in coolant or vice versa and my mechanic friend has performed a head check which didn't indicate any gasses passing into the coolant. I've also replaced the radiator cap with a brand new GKtech one (which I have happily used on all my cars without issue)
At this point I'm considering the following:
  • Running radflush through the radiator and engine.
  • Replacing radiator and thermostat.
Anyone have any other thoughts or suggestions? TIA
https://www.sau.com.au/forums/topic/485466-rb20-r32-overheating/
Have done a few different things.
First - Left the car running for 45 minutes with bottle stuck in the open radiator cap and slightly filled the bottle so that the highest point was above the top of the engine. occasionally blipping the throttle until bubbles stopped coming out.
Second - Started same as above but left the radiator cap on and cracked the bleed valve on top of the intake plenum until bubbles stopped coming out of there.
Did those two a few times.
Finally - Basically the same as #2 but drove the car around, brought it back into the garage and cracked the bleed valve until no bubbles.
Happy to take suggestions on any other methods I should be trying.
Stock radiator with shroud and gktech clutch fan (which is working).
Nismo thermostat but this was installed >5 years ago
It had been running fine with these for quite some time until the empty radiator incident.
9 minutes ago, Dose Pipe Sutututu said:
maybe also pop the stock fan blade back on
17 minutes ago, 32_love said:
gktech fan
8 minutes ago, 32_love said:
Can't hurt to try.
This is where I'd start. I like GKTech stuff, but there are more reports of that particular fan not working on RBs than there are reports of it being even as good as stock, let alone better.
Also, inspect the radiator. How are the fins? If many are bent over, then you will suffer.
Also look at the overall air path from grille through to the radiator core. Is it set up to allow air through the front mount to just spill out the bottom instead of going through the rad? Some corflute sheeting might help.
Edited by GTSBoy
  • Like 2
I'd be re-doing the head gasket check(Combustion leak), can be very subtle and given how long it takes to overheat, likely a small break in the head gasket.
Agree the gktech fan needs to go but assuming you are in brizzy it should hold up to 25degree weather.
Out of the 5 or so times I've had this problem, only once was I lucky enough to have a stuck thermostat.
The rest, pull the head off fun times.
I hope for you this is a lucky one :)
  • Like 1
I agree, particularly if the test was done before the engine was warmed up (which is how you would normally do it so you don't burn yourself).
Have you confirmed it is not loosing coolant since the first instance?
Also, has the overheating after a while thing only been happening since it got hot, or did it do so before that as well?
We let the engine warm up as much as it could while stationary and with the head check plugged into the open radiator but I see you're point that it would be difficult to get it to the point where it begins to overheat.
The overheating issue only began after the initial problem with the empty radiator. Until then I had driven the car almost daily without any issues (with the gktech fan etc.)
I'm beginning to suspect butters may be right and that it's a head gasket issue, just difficult to find the time to work on the car lately. And whether or not it's even worth doing the head gasket etc. on the 20 when I am, extremely slowly, building a 25 for this car.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
