GTX series turbos, albeit reliable are quite dated now.
I run a Garrett GTX3576R Gen 2 with a T3 1.01 divided housing and I get 0.8bar of boost by 4000rpm and about 4600rpm is when it's all in (1.8bar) on a 2.5L, VCT NEO, 264/272 cams + usual mods.
Makes a sensible 437kW on E85. I do rev the motor to 8600rpm but at about 7500rpm or so it's not making anymore power.
If I had the opportunity to do it again, I would get a Turbosmart 6262 or a Garrett G35-900. Probably same response but will go 500kW+
  • Like 1
4 hours ago, Eric0 said:
I’m thinking of parring the G30-660 with a T3 .82 twinscroll. What do you think?
Which brand turbine housing are you getting?
Garrett seem to have dropped focus on anything twin scroll as of late. They only have it in T4 1.06.
That’s what I’m noticing… seems like a popular size is 0.82 A/R, I’m considering this:
T3 twinscroll .82AR, but I’m unsure what brand because I’m not seeing Garett having the option.
Awwww, the 7670 was the best turbo I ever had! But it (and the 660) is probably 'too big'. It also does come in twinscroll and T4, waaaah, return the Garrett!
Realistically either is going to be great, presumably you can find a suitable housing for the rear. I had a T4 1.05 rear with the EFR (it's the only option, too) and it was great response wise, but I also had a 2.8.
Garrett's 1.05 might be alright? I mean they make it for a reason after all. Surely they don't expect the G30-660 to be suitable for like a 4L motor only and couldn't conceive of having a smaller housing for a smaller motor...
Those are some serious numbers! Based on the input I’ve received, seems like the G-series would be the move for same power and response 🙌🏾
Thanks for sharing, and confirming that a G-series turbo is the move! I can post my before and after dyno results and see what changes going from a GTX to G-series has
  • Like 1
I’m seeing T3 to T4 twin scroll adapters. This should work?
https://privatelabelmfg.com/products/precision-works-t3-to-t4-divided-turbo-flange-adapter?variant=34085762138250&tw_source=google&tw_adid=&tw_campaign=18293857672&utm_term=&utm_campaign=**LP+Shop+-+pMax+-+Precision+Works&utm_source=adwords&utm_medium=ppc&hsa_acc=8464848152&hsa_cam=18293857672&hsa_grp=&hsa_ad=&hsa_src=x&hsa_tgt=&hsa_kw=&hsa_mt=&hsa_net=adwords&hsa_ver=3&gad_source=1&gbraid=0AAAAADla3MIVCZh3G3-4mL4aDYDUhP9n8&gclid=EAIaIQobChMIo9q-2PyEiQMVmA6tBh3enzi_EAQYASABEgIgnfD_BwE
Feels kinda silly stacking plates and adding another gasket.
Sorry for some reason I thought you had a T4 Twinscroll manifold, not T3! I wouldn't put adapters on adapters. Just another gasket to fail or thing to sit in the wrong spot or other annoying complication.
  • Like 1
Well… maybe I do go back and look into the 7670? I’m seeing a .72 T3 twinscroll option.
how does the spool compare to the g30-660 series?
Issue with this are gaskets failures (x2) as mentioned above also it raises the turbo up further which may cause packaging issues etc.
I suppose if you have an experienced fabricator around, you could cut off the T3 flange and weld a T4 divided flange.
Another option (probably better) is to find an experienced turbo builder and they can machine a turbine housing to suit.
I would even ask Tao at Hypergear to machine and send one over to you. Might end up cheaper for you.
I’ll reach out to him and see what options we have on building a custom housing. I’ll report back
9 minutes ago, GTSBoy said:
Close, but it’s not a twinscroll housing :( looking for a divided T3
Ah, yes. I forgot that part.
At this point I would concur with the earlier suggestion of having the manifold modded to get a T4 TS flange put on. I don't think there is a T3 TS housing option for these.
On top of that, there is the whole problem of what is your expectation for a wastegate?
Edited by GTSBoy
I’ve reached out to HyperGear to see if they could build a compatible exhaust housing. We’ll see what they say!
I currently have an external 44mm tial wastegate on my manifold.
10 hours ago, Eric0 said:
Posting an update:
Contacted HyperGear, Tao said he might be able to build a T3 .82 TS Vband! Waiting to hear back on cost and shipping.
Update 2: To make a custom TS T3 .82 Vband housing to suit a G30 super core, it will be $1000AUD. I’m still inquiring shipping cost
9 hours ago, GTSBoy said:
Not too bad. Horrible compared to non-twinscroll options available, but not as much as genuine. So....workable.
Probably still smarter to convert manifold to T4.
Update 3: shipping will be 100AUD.
I do think a total of 1100AUD is doable for a custom built G30-660 T3 TS .82 A/R Vband, but I’m also finding T3 to T4 TS adapters for $67AUD and a .85 A/R TS T4 housing for 500AUD.  I know the turbo would sit about 1.25cm higher (which means redoing my downpipe and intercooler piping) and two gaskets…
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
