It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn.
Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing
Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
7 hours ago, Kyer32 said:
so I need a new speedo cable
Nope.
The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head.
To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy.
I had to manually (and delicately) clean the gunk out of my speedo.
1 minute ago, Kyer32 said:
My tyres are 215/45/r17 the 32 is a type m
On 8/1/2025 at 7:21 AM, GTSBoy said:
Nope.
So if anything it’s be the seal speedo drive sorry it’s being awhile since I worked on one of these is the drive connected to the gearbox or behind the cluster
Yep !
Cluster out first.
Dismantle.
Check for oil grease. If oil and grease = clean.
Then check seal at the drive coming from the gearbox.
Seal broken  = change seal.
Doing it the other way around it will again push grease/oil back into the cluster and then your gonna have to do the cluster clean all over again !
On 7/1/2025 at 11:26 PM, GTSBoy said:
I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
On 7/1/2025 at 11:32 PM, niZmO_Man said:
Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
1 minute ago, MBS206 said:
What makes you guess that tyre size specifically?
Just tried researching factory type m spec that’s all I can find
Search for your VIN in gtr-registry.com and see what it left with from factory. There's 4.3:1 and 4.11:1 diff ratios IIRC, can't remember what models had what.
Also could be tyre size, by factory the speedo reads a tad quicker >80 km/h but constantly out be 10 km/h is weird.
Maybe someone wound the odometer back, and accidentally bumped the needle up?
Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine.
The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember.
On 1/12/2025 at 9:44 PM, GTSBoy said:
No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare.
4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11.
4.11 and 4.08 were R33 namual and auto respectively.
The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them. :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
