I've watched a basic videos on how a petrol car engine works. It would be good to find some more in depth stuff. I plan to do a few builds in the future and I would like to know how I can get hands on instead of sending it into a shop all the time.
On 05/06/2025 at 2:31 PM, PranK said:
What 'in depth' are you looking for ?
Exactly how each part works and how they all work together to make the engine function. That's all I'd need to do a basic build. Maybe how forced induction works.
I probably need to learn some of the maths behind it all as well.
What are you planning to do specifically?
I would be very surprised if you need to learn any math for these 'few builds' you have planned for the future.
I have a terrible idea to twin charge a BNR34. Or an r35. So compression ratios and how they work as well as what certain measurements do for an engine (bore that sorta stuff). I will probably upgrade what ever engine it is with forged rods and pistons and some other strength upgrades.
Not trying to be rude here, I'm guessing your currently not old enough to drive yet?
If this is the case, I'd stick with just watching stuff on youtube. If you find the right channels you can actually learn quite a bit there.
  • Like 1
How could you tell??/??/???/? Yeah I got no idea what I'm talking about haha. I'll be on P's soon.
Quote
Yeah I figured that would be the case. Just wanna start learning to see how stupid of an idea it is. In general, I want to know so I can mod in future. It's interesting to know.
Thanks!
@RA708
All good mate.
Once you get your first car and can get hands on, that's when you'll really start to learn.
There are a million channels worth watching on youtube, but I'd like to make a recommendation. Check out the project binky series. Just a little bit of modding happening there, I think you'll find it interesting :)
 https://www.youtube.com/@BadObsessionMotorsport
  • Thanks 1
Save the youtube time, I can explain in a couple of sentences:
Internal Combustion Engines run on smoke which is factory installed. If at any time the smoke escapes (generally via the exhaust), the engine will stop running.
  • Haha 2
That's not completely truthful now is it? Any flex fuelled factory cars also had the option to run on steam.
  • Haha 1
And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
  • Haha 1
Oh ok that makes so much sense. Thanks for clearing it up!
And here I am purposely injecting water into my engine for the steams haha
  • Haha 1
Do a degree in mechanical engineering specializing in combustion systems and materials. Learn how to actually wrench on things that don't require 70k+ USD buy-in while you're at it. You also want to learn to weld and machine. If you still want to do this then you'll nominally have the knowledge to actually do what you're thinking of doing. Whether you still want to do any of that once you've actually gone through that process is anybody's guess.
Personally I cannot imagine anything more frustrating than trying to package a supercharger under the hood of any of these cars when the turbos are already fighting for every last inch.
  • Like 1
Package SC on exhaust side.
Remote mount turbo.
Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still!
Might be easier to just start with the Nissan March though... All the work is already done for you... :P
Edited by MBS206
  • Like 1
Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value.
Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach.
I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions.
It's all a ball ache.
  • Like 1
Just run it on methanol, and add a touch of WMI. :P
  • Like 1
If you haven't already decided on a career, look at being a mechanic, engine reconditioning or mechanical engineering.
All 3 will give you different views and levels of knowledge (eg, mechanic is general for the whole vehicle, reconditioning will teach you engine specifics, engineer can design stuff).
Or.......find something you love doing, hope its a well paying area and pay someone else to build the car for you.
After 20 years of mechanicing, I've lost the passion for working on my own car. It may be different if I had access to a hoist, but it is what it is.
  • Like 1
Already decided on a well paying career but it's not anything to do with cars. It would be a passion project that I would do on the side for the sake of doing it. Paying someone else to have the headache takes the fun away...
Maybe I'm cursed to just ogle at good builds and to day dream about my own.
Hopefully you get there one day.
But, there's a lot that goes into a build that may or may not be common or even specialised knowledge.
Then fabricating things that are one offs due to not being a common modification(eg, manifold and piping for twin charging).
Keep in mind, most superchargers(if using that for the low end) that are turbo style have closer output to an exhaust driven turbo. Vane or roots would be better. Maybe a sequential twin setup, but generally these are scrapped on stock cars for a decent single set up.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
