just out of curiosity and so i can get an idea of the diversity of SAU people... what do u all do???
whats ya job and who for?
Job: Global Help Desk Consultant (Asia Pacific Region)
Employee: Altria
www.altria.com
https://www.sau.com.au/forums/topic/49180-what-is-it-u-do-exactly/
  • Replies 151
Im a 4th year Mechanical Engineering/Arts student.
I also work at a pub in Mornington
And I work as a student engineer at Champion Compressors, Australia's premier air compressor company: www.championcompressors.com.au
Hey Inark,
I'm a mechanical engineer working in the petro-chemical industry as a contractor. At the moment I'm employed by Shedden Uhde at one of their site offices.
Hey inark if you work for Altria you might work across the road from me in moorabbin, right??
My brother and I have our own business's which are mainly all property related, construction, body corporate, finance...amongst other things we have our fingers in.
But our misses reckon our job is doing www.sweet-fu(k-all.com.au, and having too many bullsh!t meetings. the girls are half right :P
Hey Inark,
is that UR black R33 GTST parked across the rd???
ooSAUoo sticker on the back window with what looked like R34GTT rims???
http://www.skylinesaustralia.com/forums/sh...4&postcount=446
I'm a Sales Engineer/Machine Designer/Manager of a Machinery Manufacturing Company in Mitcham
We build machines that make metal roofing, Folders, Rollformers etc.
www.machinemakers.com.au (excuse the shithouse website)
Well if you've noticed me on here pretty much between 9 & 5 everyday, you may have guessed that I work for the government. :P
I work for the Department of Justice, with the emergency services, so basically, surfing the net all day...these server outages are killing me!
Yes mate that is my 'line with the SAU sticker on the back window and R34GTT rims. Why haven't I seen the Ceffy beast yet??!! Surely I would've seen the pimpmobile cruising into work by now!
Anyway PM me your ext no or just email me....I'm in the work address list somewhere!!
Post Whore!!! :P
Actually as most know, I'm a weapons engineer with defence (uniformed sector) but was previously a wepons acquisitions project manager and armoured vehicle fleet engineer (among many other grubby little things they had me do). Only for a bit longer then I'm bludging in Qld :)
i'm a police officer working in a division with the EPA stamping out modified cars that plague the streets of victoria... :P
and in my spare time (monday - friday, 9 - 5) i am completing Honours in a Bachelor of Biomedical Science through Monash university.
My laboratory is at the Alfred Hospital, and my project title is "Retroviral manipulation of Bone Marrow for the prevention of Type 1 Diabetes".
Basically: I do stuff to mice that are suppost to get diabetes to prevent them from getting diabetes, with the hope that this technique can be adapted to many other forms of autoimmunity (MS, gastritis, arthritis) and eventually transfer to a human treatment to cure sick people!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
