  • Replies 218
R32Big_boy: When I was going to the track I followed one rule and one rule only. Go faster than you went last time doesn't matter if you go 0.01s faster or 10s faster as long as you improve. It is the only comparison that is relevant.
If you look through Motor magazine and see what times Cameron McConville gets out of stock cars (1'48" from stock Evo 6.5 (from memory)) you can see that there is so much speed left to get from the driver before wasting money on the car.
Suspension and brakes are the best upgrade as I look at them both as reliability upgrades. Riding the bump stops around southern loop on the stock suspension is no good for anything.
Did you mean turn 6...? Not much of a drift action was happenning, you were mostly spinning them on a straight line. A lot of smoke though, the girls thought someone blew up. :P
You were too slow anyway, so i took you over. :)
What can I say, I lack traction on street tyres :wassup: Thought I might loose you in a cloud of smoke.
....If you look through Motor magazine and see what times Cameron McConville gets out of stock cars (1'48" from stock Evo 6.5 (from memory)) you can see that there is so much speed left to get from the driver before wasting money on the car......
:werd:
Godamn i am soo enverious of you lot. Hopefully i'm getting brakes and suspension within a month or so. That way troy and i can go at gtst style. Not that i'll stand a chance against any one.
Forget suspension, and for brakes all you need is some good front pads and some good fluid, you are only doing max 5 hard laps, if they start to go away just give them a lap to cool down.
I wasted plenty of money on susp only to go 0.5seconds quicker around Wakefield. Over the next 18months i pulled 6 seconds out of my best lap time without a single mod.
Just get out there and enjoy it. Unless your Scotsman, odds are your car will be far quicker then you the first few times :)
Jarrod - look at Adz. He was running street tyres (mostly), stock suspension and stock brakes. He was doing fine. Yeah sure he wants to improve all of those things eventually but he was still out there giving it a go and learning.
As he can vouch once he chucked on the semi's - you will appreciate the upgrades more if you've had a run with out them for comparison!
Anyways..... whats the next plan boys? We have to get this Sydney sider Duncan out to some real tracks (especially Sandown and Phillip Island so he can actually go fast on a track for a change! haha!)
Roy what brake fluid / pads are good for road / few track days which dont need 1 lap to get warmed up and wont spew brake dust all over ya rims?
Denham,
They say you shouldn't use "street pads" more than once on the track. If you are going for a track pad thats also ok on the streets (like RB74's etc) then the fact is they are dusty.
There's no such thing as a non dusty / non agressive when cold pad thats good on the track.
I'm using the Castrol SRF brake fluid which is awesome - but not cheap.
However - if you want a good read on people opinions on lots of different pads that people use on the track then check out this thread.
http://www.mrtrally.com.au/forums/topic.as...asp?TOPIC_ID=36
Racebarkes recommend RB74 front and Comp 2 rear for the GTS25t. I'm happy with the RB74 front and the rear do very little. I also use Motul DOT 5.1 fluid and had no fade on PI or Sandown. At PI I was out braking a lot of serious track cars on semi comp rubber, but I doubt they were using their capacity.
Word to the wise team. Don't spend a lot of bucks to find this is not your thing. The only people who will be impressed with your mods is yourself. Non trackies have no concept of what you do and the rest of us trackies will have loads of respect for you just for having a go. Just do the safety basics of brake pads and car fluids and get out there, but gently at first. You will sooon establish what is absolutely necessary.
How do you find that brake pad combo during daily driving geoff??
And what price are these roughly??
Really good performance, althought they feel a little wooden afetr an event for a couple of days. I need to bleed again I think as my pedal is dropping a bit far.
They don't grab on application but resond well to increasing pressure and when you really push them hard they REALLY start to work a lot harder. I've had some track pads that you had to really muscle when cold.
Price is around $150 per axle.
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
