I just had my garage broken into and my spare wheels and tyres stolen.
They are my Original GTT wheels which everyone recognises of course and I've found a pic of one of them.
They forgot to take the centre caps also which may help find them.
They have some quite worn Falkan tyres on them and I'm so glad I hadn't gotten around to putting new semi slicks on like I had planned.
I'm in Sydney Eastern suburbs but they could be anywhere around so if people see them advertised or see someone who just got a set cheap without the centre caps then please let me know.
Thanks.
Fkucinlg theeving priks - sh1t barstard cow **** hoar anus
Sorry to hear Bob
Keep an ear to the ground - in the trading post, e-bay, parts trader, and your local dodgy workshop !
I don't think I'm covered. Am still trying to figure it out.
Thanks for the condolences and peeled eyes guys. I will be checking trading posts and the like.
They didn't try to take the car thank god (or whoever) and the car was very clean so the cops are hoping that they left some fingerprints on it.
Cops were really good about it. Came around within an hour and are fingerprinting some time today.
sorry to hear bob , i'll keep an eye out someone will want centre caps for them .
you wont be covered by your contents insurance , they dont cover cars or car accesories .
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
